Foxbody rear springs? Here we go again - Mustang Evolution
Old 11-18-2014, 08:30 AM   #1
N2oHappy's Avatar
Long story short I got a 1990 v8 lx convertible with Eibach lowering springs, Bilstein suspension and bbk non-adjustable rear arms.
The problem is that 245-45-17 tires will rub badly as it's too low, can't imagine now my 275-45-17 to fit in for drag races..
What are you guys suggesting, I read a lot and figure out maybe some "GT springs" would be good just not sure where to find these?
Thanks to everyone,
N2o Happy
N2oHappy is offline   Reply With Quote
Old 11-18-2014, 11:41 AM   #2
Chris01's Avatar
What wheels and offset do u have? Where does it rub?
Chris01 is offline   Reply With Quote
Old 11-18-2014, 12:34 PM   #3
N2oHappy's Avatar
I have wheels from a 99 gt, often called starfish model.. sorry cant tell the offset but is rubing at the fender lip, small chunk of tire have been cut-off
I will have the fender rolled this spring but its not going to be enough as I need a small lift of at least 3/4"
Old 11-18-2014, 12:57 PM   #4
Chris01's Avatar
Yea you might just have to lift it back up a little and roll the lips. I have my v8 rear spring cut one coil off. it looks good and is good for the strip. Fox v8 lx/gt rear springs have a good spring rate for the strip
Old 12-09-2014, 10:56 PM   #5
EggOfNogg's Avatar
From what I understand fox 4 cylinder springs and v8 springs are the same but the 4s are a little bit shorter. Cheap easy lowering mod used by local guys around here. Just food for thought.
EggOfNogg is offline   Reply With Quote
foxbody
8.8 rear end from a foxbody to a 2004 V6 Mustang mazen123 Pre-2005 V6 Mustang 3 07-11-2014 12:51 AM
Foxbody Rear Differential Question crroy71 1979-1995 Mustang GT 14 04-17-2014 06:04 AM
Foxbody rear ends? Fox Fan 1979-1995 Mustang GT 3 08-26-2012 07:04 PM
New Here - '88 Foxbody 1988stang New Member Introductions & Greetings 16 04-10-2011 10:02 PM
All FoxBody Owners in Here bluemustang Mustang Audio & Video 8 04-26-2007 01:43 PM
12:42 AM
