351w HP estimate - Mustang Evolution
Old 11-22-2014, 03:10 AM   #1
92fox's Avatar
351w HP estimate
I will be building my 351w for my 92gt very soon and I wanna know how much HP it will make at the engine!! So give me your best educated guess or let me know your HP #'s of you stock bottom-end 351 Efi & your h/c/i combo!!
-Stock bottom end
-Flat top Pistons +12 (10.5:1 w/56cc)
-Trickflow 11r 190cc heads 56cc
-Comp cam xe266hr .544/.555 1.6rr
-Trickflow r intake for 351
92fox is offline   Reply With Quote
Old 11-22-2014, 08:19 AM   #2
Laquisha's Avatar
Somewhere between 200-1000 goodluck man
Old 11-22-2014, 04:04 PM   #3
92fox's Avatar
Lol thanks but I need a educated guess
Old 11-24-2014, 07:13 AM   #4
Somewhere in the high 300s/low400s I'd guess. Depends on the rest of the mods on the car.
Stock bottom end as in stock crank and rods? If you are using stock rods, make sure to use the "football" rods.
2000 Mustang GT Steeda #0048
Old 11-25-2014, 03:01 AM   #5
92fox's Avatar
Yea that's a good hp range, I'm hoping for 360hp & up at the wheels, but I'm pretty sure they are the football rods bc the block is out of a truck.
Old 11-25-2014, 06:52 AM   #6
You'd have to look at the connecting rod bolt to be sure. Regardless if you are going to stick in the 360-400whp range, any stock rods will be just fine.
Old 11-25-2014, 10:30 AM   #7
smurf stang's Avatar
Make sure you use good fasteners.
2016 VW GTI 2.0 Turbo
Old 11-26-2014, 02:22 AM   #8
92fox's Avatar
Have any of you guys used or know someone that uses the trickflow 11r 190 heads, if so how do they like them and how do they perform ?
Old 11-26-2014, 07:18 AM   #9
I've used 170cc TW heads before and TW is probably my favorite brand of heads for the 302. High quality, good design, make power and price is reasonable.
Old 11-26-2014, 07:53 AM   #10
Had 170's on the 302 and then had them ported when I built the 347. Great heads and love what they do.
Old 11-26-2014, 08:35 AM   #11
That's the other thing, there is PLENTY of "meat" on a TFS 170cc head (or 190) for a porter to work with if one ever steps it up. Lots of 408s out there running ported 302 heads that flow well enough to make great power. Cheaper than buying new heads if you already had them on another build but if starting from scratch, just get the size you need.
Old 11-26-2014, 10:52 AM   #12
My friend/local guy got my heads flowing into the low 300's/230's @ 600 lift and not lazy at all down low either.
estimate plz upton7 General Mustang Discussion 4 04-03-2009 03:36 PM
estimate horsepower at the crank an at the wheel juced302 1979-1995 Mustang GT 8 03-05-2009 12:37 PM
Estimate using MPH... Stang_1973 Pre-2005 V6 Mustang 6 12-16-2004 08:59 AM
got an estimate today *advice desired* dark The Bar 8 09-25-2004 05:50 PM
94-95 and 96+ v6 rods, and 351w/351w truck rods tire Pre-2005 V6 Mustang 1 02-21-2004 02:37 PM
05:23 AM
