Coil springs - Mustang Evolution
Old 11-22-2014, 09:36 AM   #1
Coil springs
Hello. I am looking to buy a set of coil springs for my 91GT. Right now they rub in the rear when I hit a dip in the road or a bump. Can anyone tell me the best springs to get that is the 'best bang for the buck'? I've seen Eibach, Ford Racing and H & R along with many others. Not sure what to get. It is lowered already when I bought the car and it did not rub. It is also my daily driver
jsdoogie91gt is offline   Reply With Quote
Old 11-22-2014, 01:27 PM   #2
Ford racing C springs will give you a mild drop. These may be the ones to get. I recently had the Sr performance springs on my 14 and its a dd. nice drop not to low
Bigshow14 is offline   Reply With Quote
Old 11-22-2014, 09:53 PM   #3
Ok Bigshow14, any idea where to find those springs at? Thanks
Old 11-23-2014, 01:06 AM   #4
NewMtang's Avatar
Check with the manufacturer of the rims, you may only need a 5/16 spacer. I had to get them because I didn't have enough clearance on my Bullitt rims and the MGP Black Caliper Covers.
Old 11-23-2014, 09:27 AM   #5
Ok
Old 12-07-2014, 01:15 PM   #6
Would you guys recommend the ford racing lower springs that are specific or progressive rate springs? I know 1 is more stiffer than the other
Old 12-08-2014, 09:34 AM   #7
Remember you are going to need new shocks/struts if you lower and cc plates up front. Yes, they are needed to properly lower. In answer to the question, hr blues are good as are the ford springs.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 12-08-2014, 09:51 AM   #8
smurf stang's Avatar
The ford racing springs are nice and not too low that you will be a low rider.
CC plates are always a great thing to have to have it set up right even on a stock car.
Shocks and struts make a huge difference like the other boys told you.
2016 VW GTI 2.0 Turbo
Msd Coil or Screamin Demon Coil? NinjaStang Pre-2005 V6 Mustang 33 03-13-2014 11:12 AM
coil pack or coil on plugs? Joe_Roma5 2005-2010 V6 Mustang 11 01-04-2013 09:20 AM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
Wanted: Stock coil springs and stock mufflers for '96 GT inaba116 Mustang Parts for Sale and Wanted 6 02-15-2006 09:19 PM
coil overs vs. lowering springs STEVE Pre-2005 V6 Mustang 6 06-13-2004 02:36 PM
10:36 AM
