94 gt broke down - Mustang Evolution
Old 11-29-2014, 10:35 PM   #1
Beau_123's Avatar
94 gt broke down
Okay so I had to park my car at a friends house tonight because that is all the farther she would make it. I wasn't driving very agressive today at all. But the problem is when it is in drive the car sounded like it is in neutral just reving up and won't move I tryed shifting it down to first then second but the same thing is happening. and there is this god aweful noise coming from the trany area. I first thought it was the drive belt loose cause that's what it sounded like but it's coming from the trany.
Beau_123 is offline   Reply With Quote
Old 11-30-2014, 08:50 AM   #2
Shifty 5.0's Avatar
Sounds like you're going to need a new trans...
Shifty 5.0 is offline   Reply With Quote
Old 11-30-2014, 08:55 AM   #3
Shifty 5.0's Avatar
Sounds like you're going to need a new Trans... That happened to a buddy's of mine trans and it was toast
Old 11-30-2014, 08:56 AM   #4
Beau_123's Avatar
Okay so if I have to get a new trans should I swap it to manual how much more would that be?
Old 11-30-2014, 09:35 AM   #5
Shifty 5.0's Avatar
You will have to find a T-5 and I see people do them all the time for right under or around $1000. You have to swap the PCM a lot of cables etc etc. do some research on it and you'll find a lot of info seeing how it's a very common thing to do.
Old 11-30-2014, 11:37 AM   #6
Beau_123's Avatar
Update. Okay we are pretty sure it is electrical because the car will drive after it is turned of for a little bit but then it won't get into gear after driving it for like a minute. Would we be right and saying that it is electrical?
Old 11-30-2014, 02:40 PM   #7
As shifty 5.0 stated above trans is toast. Round up t-5 swap parts or rebuild the ole Aode.
Bigshow14 is offline   Reply With Quote
Old 11-30-2014, 05:54 PM   #8
Soda56k's Avatar
By chance did you check the fluid. Is there any in it? Is it leaking any.
Sent from my LG-D800 using Mustang Evolution mobile app
Soda56k is offline   Reply With Quote
Old 11-30-2014, 05:59 PM   #9
Beau_123's Avatar
Yes there is fluid
Old 11-30-2014, 08:07 PM   #10
aforceman's Avatar
What is happening is the bands inside the transmission are warming up then it no holds no more. New trans
aforceman is offline   Reply With Quote
Old 11-30-2014, 08:45 PM   #11
Beau_123's Avatar
So can it be fixed or does i need to buy a new trany
Old 12-01-2014, 10:23 AM   #12
New trans. Now would be a good time to get an AODE built with 4R70w guts and a nice converter. Car will feel like a completely different animal.
Old 12-01-2014, 10:45 AM   #13
Beau_123's Avatar
94 gt broke down
Okay I am going to be honest here I don't know what half that means. Where would I find one if these and is that manual? Because I would like to get a manual
Old 12-01-2014, 02:46 PM   #14
AODE is the auto trans you have now. 4R70w was 96-up but pretty much everything now is going to be the 04 revision which is very very strong. A converter is basically the "clutch" for the auto.
If you have a 94/95 car and want to get a manual, there are extensive swap threads on how to do it. Plan on spending about $1500 if you are doing it yourself. If having a shop do it... I'd just get a rebuilt auto and call it a day...
Old 12-01-2014, 02:54 PM   #15
Beau_123's Avatar
94 gt broke down
What are the pros and cons of rebuilding the automatic and/or swapping to a manual?
Old 12-01-2014, 03:14 PM   #16
Well are you comfortable pulling the exhaust/transmission out and doing the conversion yourself? If not the biggest pro for the auto is going to be a shop is going to be able to just pull and swap in a new auto directly and it'll be cheaper.
Old 12-01-2014, 03:30 PM   #17
Beau_123's Avatar
Well it's already at a shop so I was just gonna have them swap in a manual.
Old 12-01-2014, 04:03 PM   #18
smurf stang's Avatar
Well swapping in a manual at a shop is gonna cost ya 2k will everything all said and done.
A AODE/4R tranny will be 1800 to 2000 with everything, approx.. Plus it will hold way more power and shift snickity quick.
2016 VW GTI 2.0 Turbo
Old 12-01-2014, 06:30 PM   #19
Foxbody91's Avatar
Any special reason you want a manual trans? Bigger goal?
Foxbody91 is offline   Reply With Quote
Old 12-01-2014, 06:31 PM   #20
Because MAN PEDAL!
Old 12-01-2014, 06:35 PM   #21
Beau_123's Avatar
94 gt broke down
I would like to have a manual to save gas and get better headers on it. And get all of what I want out of it
Old 12-01-2014, 06:39 PM   #22
MAC longtubes fit with the auto just fine and can be installed with the motor in the car. Driver's side comes up from the bottom and the pass side goes in from the top. Motor must be jacked up all the way until the back of the intake touches the firewall and the starter removed. Takes someone who works on these things relatively often 3-4 hours working alone. Stage 8 locking bolts are always a must IMO.
Old 12-01-2014, 06:41 PM   #23
Foxbody91's Avatar
Because MAN PEDAL!
Truu
Old 12-01-2014, 06:42 PM   #24
I was actually being sarcastic lol. ppl who say **** like that have never driven or ridden in a legit fast automatic. If they had, they'd stfu about how autos are for sissies or whatever.
Old 12-01-2014, 06:47 PM   #25
Foxbody91's Avatar
I've never had a beasty auto at all. I've always preferred manual to auto one because I'm the only one in my family, and two...seems most of the idiots in my city who steal cars can't drive stick
Old 12-01-2014, 06:47 PM   #26
Beau_123's Avatar
Okay I think I'll go with the automatic build what do I need to buy for the shop to put on?
Old 12-01-2014, 06:53 PM   #27
Well what is your budget? You should also replace the converter while its all out. I'd get quotes from this shop for an auto rebuild vs the manual swap. See if they know what you are talking about when you ask them if they can use 4R70w internals and install a shift kit. If not, you might want to get in touch with a builder and have one shipped in. Also not sure what your downtime can be on this thing.
3 weeks and broke down bosscityboy86 1996-2004 Mustang GT 9 01-04-2007 07:00 PM
Dammittohell Broke Down!!!! Danger Dude The Bar 19 06-01-2005 07:33 PM
broke down today v6stangracer Pre-2005 V6 Mustang 8 03-07-2005 11:07 PM
finally broke down and raced the evo. Monkey Pre-2005 V6 Mustang 17 09-28-2004 03:18 PM
so i finally broke down (tire q) tire The Bar 20 10-06-2003 08:00 AM
02:18 PM
