89 question - Mustang Evolution
Old 11-30-2014, 11:47 PM   #1
kyle_rivas's Avatar
89 question
On cold start my car will idle just fine for about 2 minutes and then slowly cut off and now it is stalling out a lot I was thinking the fuel pump isnt working properly and giving the fuel lines enough gas it sounds like its suffering for gas is it the pump or something else I have a 1989 5.0 thank you.
instagram @5.0_rivas
kyle_rivas is offline   Reply With Quote
Old 12-01-2014, 07:05 AM   #2
smurf stang's Avatar
What makes you think the pump is weak?
What is your fuel pressure?
What is your pressure with the vacuum line pulled?
Did you ever run your codes?
2016 VW GTI 2.0 Turbo
Old 12-01-2014, 10:27 AM   #3
kyle_rivas's Avatar
I ran my codes it did a lot better its just now it seams like the gas isn't getting to the injectors good enough
Old 12-01-2014, 10:31 AM   #4
What leads you to believe that? Have you checked your fuel pressure at the rail? Did you ever get that dyno tune since you don't have a stock cam?
Old 12-01-2014, 11:19 AM   #5
kyle_rivas's Avatar
I haven't got the dyno tune yet and I haven't checked the fuel pressure yet
Old 12-01-2014, 01:37 PM   #6
Check the pressure.
Vacuum line on and off.
Old 12-01-2014, 06:36 PM   #7
Foxbody91's Avatar
Lol check the pressure, and get it tuned buddy it'll help u start eliminating a lot of ur problems
Foxbody91 is offline   Reply With Quote
Old 12-01-2014, 06:41 PM   #8
I've been telling him that for literally months. He keeps asking the same question in a different way. "How can I get my car to run right?"
Get a tune.
Old 12-01-2014, 06:51 PM   #9
Foxbody91's Avatar
Get a tune.
Lol the stubborn type. I learned the hard way too.
Old 12-01-2014, 06:55 PM   #10
The crazy thing is, the myth that the fox computers are some crazy magic processors that never need to be tuned is still really prevalent. They can do bolt ons much better than the 94/95 computers... but once you take out the factory cam all bets are off.
Old 12-02-2014, 09:46 AM   #11
kyle_rivas's Avatar
Guys I know this already ur answer to anything is a tune see I cant afford a $600 tune at the moment im trying to find other problems besides that maby can help im not in a rush to fix it the problem isnt that bad
Old 12-02-2014, 03:15 PM   #12
Foxbody91's Avatar
Bro trust me when I say I don't have $600 to just drop either but if u add up the $$ for all your problems you'll probably come close if not over $600. Seeing as the tune is what's the root of your problem, IMO that should be first. You could end up replacing parts that don't even need replacing. No need to get upset we are here to help
Old 12-03-2014, 09:12 AM   #13
kyle_rivas's Avatar
I know man im not upset like I said I was just trying to piece out small problems im still young here im trying to learn from mistakes and so on I guess ill just have to save up for a tune thank you
Old 12-03-2014, 09:21 AM   #14
Foxbody91's Avatar
Well as for ur post, I think your fuel pump could play a part in that..honestly I'm not 100% sure, check your vacuum hoses maybe, sounds like its not pumping fuel to keep it running so just work your way from your fuel pump on up. I'm EFI I haven't had to work on your kind of setup for awhile and when I did I was still learning it but that's the best I've got for u. Try googling your problem or YouTube it to kinda get an idea of wat the problem is in case no one here can identify the prob
Old 12-03-2014, 11:29 AM   #15
kyle_rivas's Avatar
Thats what I was also thinking the vacuum hoses may have fell off or something I haven't had time to really mess with it yet
Old 12-03-2014, 02:42 PM   #16
If you ain't got money for a tune then you better be handy and learn this car.
Learn about checking small things out yourself like fuel pressure, timing, checking for codes, checking for vacuum leaks......ect.
Next time you post back it should sound like this.....
Pulled my codes and all I got was an 11.
My fuel pressure is 40 an 32.
All vacuum hoses look good and checked for leaks 4 times.
Tune up was done recently and plugs look great.
Sorry but random questions get vague answers.
Old 12-03-2014, 03:48 PM   #17
kyle_rivas's Avatar
Sorry about my posts I understand
Old 12-04-2014, 07:41 AM   #18
Frenchstang's Avatar
IMO kyle , if your car is the only one you got , you should have not play with it because if your screwing something you gonna have to walk . If its your second car then store it and save up money for a tune and you will see its worth it !
Frenchstang is offline   Reply With Quote
Old 12-04-2014, 07:47 AM   #19
Dont take mw wrong i am not giving you hard time buddy , i have mine for almost 2 years now and i read every post so when i will start working on it i will know what to expect ! My dad always told me sometime we work on those car and because we dont know exactly what we are doing ,it make the car worse than stock ! 😀
Old 12-04-2014, 02:26 PM   #20
kyle_rivas's Avatar
Lol true I had my car for about 2 years now I have 2 other vehicles I have my jeep right now for my daily great on gas ima just wait till I get some money and then spend it all into the stang lol
Old 12-05-2014, 07:16 AM   #21
Also Kyle I don't wanna sound like I am trying to beat you down but if you were to ask a specific question it is much easier to try to suggest something. I understand it is frustrating to try finding little problems but you gotta start small and simple. That way you can go through and look for things that are free and easy to diagnose ( a little time consuming). Checking for vacuum leaks is a time consuming thing but with these cars due to their age hoses rot out, a bad egr stuck can also be a vacuum leak, simple components are not intended to last a lifetime.
So after you have spent a whole day just checking things and eliminating the obvious and the problem still persists then it will be much easier to get a professional to help you out and cheaper as you have done a lot of the simple leg work.
Old 03-28-2015, 11:11 AM   #22
Region: Rhode Island
My Mustang had a problem when cold that sounds a lot like yours. It would start fine, go to high idle for a short while, then would idle down till it stalled. Would have to keep it running with my foot. If it was warmed up and I put it in gear ( AOD ) it would try to die. The issue was fixed when I put a new Idle Air Control Motor. This bolts to the throttle body. Hope this helps.... Paul
Paul B is offline   Reply With Quote
Question question!?!? AmericanBulldog Pre-2005 V6 Mustang 11 12-11-2013 08:24 PM
Wheel gap question and lca question Mdazi 2011-2014 Mustang GT 27 05-27-2013 07:11 PM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Question: I would like to know from you guys (See background and full question)? dumont75 General Mustang Discussion 16 03-03-2010 06:17 PM
Car question? Duh, of course it's a car question, silly!? imported_daman General Car Discussion 3 08-17-2009 06:40 PM
12:44 PM
