Rear End Fluid Change - Mustang Evolution
Old 12-01-2014, 02:32 PM   #1
racks2relax's Avatar
So i got my 4.10s installed bout 800 miles ago, the shop told me to have the fluid changed after the break-in period which was 500 miles. I dont feel like dropping the girdle, can i just pump out the fluid used to break them in and pump some new fluid?
Sent from my SM-N900P using Mustang Evolution mobile app
racks2relax is offline   Reply With Quote
Old 12-01-2014, 04:05 PM   #2
smurf stang's Avatar
Yes you could, try to get all of the fluid out.
Is there a drain plug?
2016 VW GTI 2.0 Turbo
Old 12-01-2014, 06:09 PM   #3
There is no break in period for Ford gears. If they are making any sort of noise whatsoever the shop messed up and they need to be fixed and probably need a new install kit. Hopefully this is not the case.
Old 12-01-2014, 11:19 PM   #4
Its either pump it out, or remove the girdle, but i know of one more person that never replaced the fuild either.
Scotty, there is no sound, actually are great. But the shop didnt use the royal purple gear fluid that came with the Gear kit. They said to save it until the oil change. I took it to a reputable rear end shop for the install since i didnt want to mess it up myself
Old 12-02-2014, 03:24 AM   #5
bucko's Avatar
They should have used the Royal Purple...as scottyknows stated, the Ford gears do not require a break in, and any reputable shop would know this I'd say.
When I had mine done (by Ford) I had them install a Boss cover that had a drain and fill plug, plus the TSP mod for adding the "turkey baster" vent tube. If you are hard on the rear end, it can vent gear oil out the stock vent valve (on drivers side of axle). Keep an eye out on this part of the axle for wet marks.
Old 12-02-2014, 06:16 AM   #6
I'd just leave it then... I mean find out what they used but if its a good rear end fluid don't mess with it and leave the RP on the shelf for a routine fluid change in 20-30k miles.
And I agree with Bucko, if they were that reputable they'd know Ford gears are install and go, no need to break them in. The last time I had someone install a set of gears was a set of Ford 3.73s new in the box from the dealer and I thrashed the living **** out of them the very first pull coming out of the shop. Never heard a single peep from them.
Old 12-02-2014, 09:14 PM   #7
Right on, thanks bucko & scotty ill just save the fluid and keep beating on these gears.
Old 12-08-2014, 08:02 PM   #8
EggOfNogg's Avatar
So how dose your car do on the highway? I'm considering 4.10s.
Thanks.
EggOfNogg is offline   Reply With Quote
Old 12-15-2014, 12:10 PM   #9
It's not my daily so it doesn't bother me on the freeway. But the Revolutions are a little up in the 28000 rpms in OD with the car going 65mph. I don't avoid the freeway, but do enjoy driving it a lot more around town since the re-gearing.
Old 12-15-2014, 02:36 PM   #10
All depends on what year car you have and your overall tire diameter out back. Google "RPM" calculator and punch in the info you want. Stock tire diameter is 25.7" and final gear ratio is going to be .68 for 5 speeds and .70 for autos. Figure 25-2600 rpms on the highway with 4.10s and a T-5 doing 65-70mph.
Old 12-16-2014, 03:09 AM   #11
Scotty is right, or latemodel has a calculator for you before choosing your tooth. I believe you are right on point, It's been a good 4 months since my last drive. I think it was 25-26 rpm at 65mph
Rear Axle Fluid Change at 3,000 Miles???? ford302ize 2011-2014 Mustang GT 3 07-15-2013 08:12 PM
Changing Fluid in Rear End Questions? Dkerk8 General Car Discussion 10 03-20-2012 12:02 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
10:45 PM
