Radio issues - Mustang Evolution
Old 12-03-2014, 07:17 PM   #1
Foxbody91's Avatar
Radio issues
Oook I'm not sure if anyone has experience in hooking up systems, this was my first time I hooked my ground cable to the chassis in the trunk, power cable goes under carpet on driver side and through dash to my battery, RCA cables are hooked up to the rear speaker input on back of radio, and remote wire is hooked up also, it worked fine for about a week, then it wouldn't and my radio said miswiring and to restart the radio, I did and nothing, then I went and tightened the remote wire and it worked again...go over a speed bump and back to square one, everything is tight so what am I doing wrong?
Foxbody91 is offline   Reply With Quote
Old 12-04-2014, 11:59 AM   #2
Something is loose somewhere. Where exactly are your grounding it to?
Old 12-04-2014, 12:44 PM   #3
Foxbody91's Avatar
Name:	ImageUploadedByMustang Evolution1417722223.654004.jpg
ID:	170935 it's behind my rear seats under the trunk carpet
Old 12-04-2014, 02:11 PM   #4
That's a pretty weak ground, I'd be willing to be that's your problem if all that is grounding that big a gauge wire is that little screw in chassis metal...
Old 12-04-2014, 02:27 PM   #5
Foxbody91's Avatar
Word, soon as I get off work ill see if I can find a better spot. May need smaller amp and sub anyways between the two they take up most of my trunk space
Old 12-05-2014, 12:48 PM   #6
smurf stang's Avatar
Always ground it to a nice piece of solid clean metal and a nice gauge of wire.
2016 VW GTI 2.0 Turbo
Old 12-05-2014, 09:16 PM   #7
Foxbody91's Avatar
Yep I moved it, the gauge was wire new I guess I had it in a bad spot the first time
Old 12-07-2014, 09:18 AM   #8
And when I said a nice gauge of wire I meant a nice heavy gauge instead of using a 18 or 2 gauge which is thin and week.
The Bathroom
Old 12-07-2014, 01:45 PM   #9
I used 0 gage wire in my last "system". I still have the whole run of it spooled up with the old amp in the garage. That stuff is expensive now lol. Also good to know if I ever run another system I'll have it, although I'll likely put the battery in the trunk on my next car...
Mustang 99 up 6cd in dash changer Radio $200 Acha3 Mustang Parts for Sale and Wanted 6 08-26-2004 09:22 PM
03/04 Cobra Knob & MGW Radio Knob Matt@StangMods Mustang Parts for Sale and Wanted 0 07-21-2004 02:11 PM
how to take out radio bezel???? 01mineralgrey6 Mustang Audio & Video 3 02-17-2004 08:05 PM
WTB: Radio Bezel Piece v6mustangguy Mustang Parts for Sale and Wanted 0 02-03-2004 04:25 PM
radio clip of IROC Camaro idiot tire The Bar 8 08-12-2003 10:41 AM
05:47 PM
