94 gt trouble starting - Mustang Evolution
Old 12-04-2014, 12:02 PM   #1
Beau_123's Avatar
Okay so some days when it is cold out I will come out of school and my car will take a while to start. I thought it was just because it's an old car and might have a cold start but I think it might be something more than that. Any ideas what it could be?
Beau_123 is offline   Reply With Quote
Old 12-04-2014, 12:07 PM   #2
Starter solenoid or weak starter? I mean is it cranking over normally and just taking awhile to start or is it cranking real slow?
Old 12-04-2014, 12:13 PM   #3
Beau_123's Avatar
It's not cranking slow it just acts like it is really cold. Could it be that I didn't reset the timing after changing spark plugs?
Old 12-04-2014, 12:19 PM   #4
Spark plugs have nothing to do with the timing. Acting like its really cold like... cranking normally? Sounds the same? No lower pitched lugging sound? I'm just thinking it might be a bad starter.
Old 12-04-2014, 12:21 PM   #5
Beau_123's Avatar
Yeah it cranks normally. And it starts fine when it is warm out. it's just when it is like 20 degrees outside it takes a while to get it to start.
Old 12-04-2014, 12:52 PM   #6
Foxbody91's Avatar
Mine was starter and battery post detached from battery itself awhile back. Check both of those then double check. Take your car up to advanced auto and get everything tested first
Foxbody91 is offline   Reply With Quote
Old 12-04-2014, 01:39 PM   #7
Beau_123's Avatar
Yeah I get my car back from the transmission shop after school and I am going to take to orileys to get the batterie tested
Old 12-04-2014, 02:08 PM   #8
Yeah sounds like it might be a just a weak battery then. Worst case you have to change the battery or the starter. Battery is duh, starter is actually real easy to change too. Like, half hour with maybe a cut knuckle and a few 4 letter words. Not bad.
Old 12-04-2014, 02:36 PM   #9
Foxbody91's Avatar
Wouldn't hurt to check your starter cable also while your down there
Old 12-04-2014, 05:03 PM   #10
Beau_123's Avatar
So I went in and got it tested he said everything was okay. Batterie good starter good alternator good
Old 12-04-2014, 05:53 PM   #11
Foxbody91's Avatar
Um...how about checking your ignition switch, it could be starting to burn out..
Old 12-04-2014, 06:22 PM   #12
Beau_123's Avatar
Well the thing is that it starts fine when it is warm out. Could it be the fuel filter?
Old 12-04-2014, 06:42 PM   #13
I was going to say weak fuel pump is your next stop. If you've never changed the filter now is the time... when I changed the 10 yr old original fuel filter in my old Cobra and did the "blow test" I could barely get any air through it. Also test the pressure at the rail at idle and see what it is vac on and vac off.
Old 12-04-2014, 06:47 PM   #14
Beau_123's Avatar
I was going to say weak fuel pump is your next stop. If you've never changed it, now is the time... when I changed the 10 yr old original fuel filter in my old Cobra and did the "blow test" I could barely get any air through it.
Okay I will check into that what type should I get?
Old 12-04-2014, 06:51 PM   #15
I edited my post. Change the filter and then get a cheap fuel pressure gauge from autozone or wherever and see what your fuel pressure is. Also could be old injectors etc...
Honestly with a 94/95 car you're going to want to replace the injectors, pump and the rubber fuel lines in the engine bay. They're actually a fire hazard and Russell fittings custom made fittings for the 94/95 hardlines specifically so ppl could run aftermarket braided lines in place of the OEM ones.
They're 20 year old cars at this point you have to remember. If you can't do all that right now, at least replace the filter and make sure you have good pressure at the rail.
Old 12-07-2014, 05:34 AM   #16
Hellish Horse's Avatar
Sure does sound like electrical to me....but just guessing. Any chance it could be the Distributor cap & Rotor or the Coil ??? If it's 20 degrees where he's at it's probably snowing or wet too. Which makes me think moisture at the distributor or plug wires causing it to crank some before the spark actually starts the car. Just a thought....I don't consider myself a mechanic but I have had this kind of problem before.
Hellish Horse is offline   Reply With Quote
Trouble Starting 02 GT Michael.s.king 1996-2004 Mustang GT 15 04-30-2013 05:20 AM
94 gt hard trouble starting! Harned67 1979-1995 Mustang GT 1 01-03-2013 05:54 AM
Car having trouble starting, HELP! MTilly 2005-2010 V6 Mustang 3 12-29-2012 10:56 PM
95 5.0 trouble starting? blackvert18 1979-1995 Mustang GT 0 01-04-2008 09:04 AM
trouble starting bluestang1724 Pre-2005 V6 Mustang 2 05-23-2006 04:08 PM
11:11 AM
