Looking for foam weatherstrip gasket for lower shifter Shift boot - Mustang Evolution
Old 12-06-2014, 05:50 PM   #1
BossDrew's Avatar
Region: West Virgina
Anyone know if I can order the high density foam weatherstrip gasket by itself? Or even with the rubber boot? I ordered it from Late Model Restoration because the description said the weatherstripping gasket came with the rubber boot, but they lied. It doesn't.
Mustang Lower Shift Boot w/o Trim Ring (79-04)
Thanks!
_______________________________________
1990 LX Convertible / 25th Anniversary
BossDrew is offline   Reply With Quote
Old 12-06-2014, 08:57 PM   #2
Unsure what you are asking. There is that rubber boot with the metal ring around it, then the plastic bezel and boot... You can just get some strips of Dynamat if you need anything else. If you mean extra foam around the OEM metal gasket then try ordering the whole unit from a Ford dealer because the aftermarket ones are all just the metal and rubber.
Old 12-07-2014, 06:52 PM   #3
BossDrew's Avatar
Thanks. I did find it at NPD. They've got the rubber boot with weatherstripping and the metal ring. All set!
Help with shift boot and e brake boot installation. Fintile Mustang DIY and Technical 2 10-15-2014 02:48 PM
Headlight Weatherstrip escottcarp Mustang Paint, Appearance & Detailing 0 01-20-2013 09:23 PM
lower dust boot on shift eddie1 1996-2004 Mustang GT 4 10-07-2009 09:43 AM
weatherstrip vent window DAC Classic Mustangs 3 02-24-2009 05:49 PM
No t-top weatherstrip OEM or after market ? my83 horse 1979-1995 Mustang GT 13 03-19-2008 01:40 AM
03:48 AM
