Pushrods Length - Mustang Evolution
Old 12-10-2014, 05:55 PM   #1
Pushrods Length
I have searched this forum top to bottom using every search word I can think of, but haven't come up with an answer.
I have a 95 GT. I bought a set of GT40p heads that have been fully rebuilt with aftermarket valve springs, pocket porting and port matching done (this is from my Father-In-Law). Can I use stock pushrods with these heads with an E303 cam? I've heard yes and no onthisdo
TIA
Jim
Vettn71 is offline   Reply With Quote
Old 12-10-2014, 06:51 PM   #2
smurf stang's Avatar
I would measure plus I would want hardened pushrods as I have seen stock ones bend.
The Bathroom
2016 VW GTI 2.0 Turbo
Old 12-10-2014, 07:18 PM   #3
Yes, guess that would be the best. Thanks
Jim
Old 12-10-2014, 07:30 PM   #4
You have to measure. People are not being asses when they suggest that and you'd be amazed at how many ppl take it that way on this and other forums. You need:
-Solid checking lifter
-Adjustable checking pushrod
-Digital Calipers
-Sharpie
There are plenty of how-tos on the interwebz (youtube) on how to properly check pushrod length on a pushrod motor.
Old 12-10-2014, 07:47 PM   #5
This is why I install studs and use stud mounted rocker arms.
Old 12-10-2014, 07:48 PM   #6
Shifty 5.0's Avatar
Definitely get hardened!!! My buddy did a gt40 build and bent the rods and the motor got killed lol the heads got ruined and some Pistons were trashed
Shifty 5.0 is offline   Reply With Quote
Old 12-14-2014, 01:21 AM   #7
Hellish Horse's Avatar
I used stock length push rods on my 94 5.0 build. I used 3-Bar GT40 Heads with the E303 Cam....So I would say the stock push rods should work on GT40P Heads too. You do want Hardened Push Rods. I hope you upgraded your Valve Springs too because they are too weak for even a Stock Mustang H.O. Cam.
Hellish Horse is offline   Reply With Quote
Old 12-14-2014, 09:38 AM   #8
Did you check the witness marks? How do you know you arent putting extra wear on your valvetrain from too long or short rods? You HAVE to measure to do it right. Period.
Install a solid checking lifter with the intake off, install a clicking type adjustable pushrod and mark the valve stem tips with a sharpie and go. Very easy. Only bad thing at all is you have to wait a few days for the pushrods to ship to you so the motor will be down for a week or so even for a simple can swap. Unless it turns out the stock length pushrods are good lol.
Sent from my VS980 4G using Mustang Evolution mobile app
How can I check if I have the correct size pushrods? JayKranz 1979-1995 Mustang GT 14 07-19-2012 06:06 PM
5.0 HO lifters and pushrods help gilo 1979-1995 Mustang GT 3 06-03-2012 05:15 PM
Pushrods? WhiteCobra94 1979-1995 Mustang GT 7 02-25-2011 05:10 PM
help with 1.72rr and pushrods svtlx 1979-1995 Mustang GT 4 01-13-2009 06:13 PM
WTB: 540 Springs and Longer Pushrods petrey10 Mustang Parts for Sale and Wanted 0 09-13-2005 11:06 AM
07:22 AM
