Door handles - Mustang Evolution
Old 12-12-2014, 12:27 PM   #1
Foxbody91's Avatar
Door handles
The famous handle problem, my passenger side has completely snapped inside and out when u pull on it, it's loose. My driver side has started acting up now on top of my window motors going out(easy fix). But before I order the parts to fix my doors I want to make sure I got it right. Rivet gun, inner and outer door handle for passenger and driver side, and the rivets, I think they come in the door handle kit. I took it to a collision center but it'll cost me $300 to fix both doors so that's a negative
Foxbody91 is offline   Reply With Quote
Old 12-12-2014, 01:52 PM   #2
EggOfNogg's Avatar
I did it my self on a ranger I have looked at mine on my stang and looks to be the same setup. The hardest part is that stupid Plastic clip connecting to the latch, I broke two of them before getting it right. I get quickly frustrated when my hands don't fit in places I need them to haha! Just take your time And keep your patience lol, that looks like all you need. A nice sharp drill bit helps. I put bolts in mine instead of rivets. Good Luck!
EggOfNogg is offline   Reply With Quote
Old 12-12-2014, 01:59 PM   #3
Foxbody91's Avatar
Alright thanks bro
Old 12-12-2014, 02:24 PM   #4
ALMOST STOCK's Avatar
FWIW: Outer door handle uses 1/4" rivets so you'll need a large rivet gun for those.
This will help with what you need and also a video towards the bottom that talks you through removing and installing the outer door handle.
Mustang Door Handle Replacement – 1979-93 Models
Here a video on how to do remove and install inside handle. Again the video is towards the bottom
Mustang Inner Door Handle, RH (83-93)
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 12-12-2014, 07:33 PM   #5
smurf stang's Avatar
What diagram, picture or video doesn't almost stock not have.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 12-12-2014, 09:49 PM   #6
Foxbody91's Avatar
Lol I know right. I ordered a large rivet gun along with the rivets and and handles, but I noticed my driver side outer handle is bolted on and my passenger has rivets. Will that cause a problem or no?
Old 12-12-2014, 09:50 PM   #7
EggOfNogg's Avatar
I'm betting someone did the same as me and just put bolts instead to save you the work next time they fail.
1991 lx 5.0 mustang x2
Old 12-13-2014, 08:09 AM   #8
As long as who ever put the bolt in, in placed of the rivet didn't use a drill bit 1/8" bigger than the 1/4 inch hole needed for the 1/4 rivet you'll be OK.
Old 12-14-2014, 08:58 AM   #9
Liebert91stang's Avatar
If it has a bolt someone has already changed them.they aren't bad to change.you will have to drill out old rivits.i would tape off around it for little protection.they do have a kit you can buy that comes with rivit gun and handles
Liebert91stang is offline   Reply With Quote
Old 12-14-2014, 09:07 AM   #10
Foxbody91's Avatar
Yep ordered the kit from latemodelrestoration, should be here in couple days ill post if I run into any issues.
Door handles Ofd468 2005-2010 Mustang GT 8 01-17-2013 08:56 PM
Need to change outside door handles TerranautX Pre-2005 V6 Mustang 4 08-26-2011 03:04 PM
Car with no door handles ? imported_Corey General Car Discussion 4 04-04-2010 12:53 PM
Door Handles 05bluestang 2005-2010 Mustang GT 1 03-06-2008 08:01 AM
did some body work tonight - started on the door handles fast64 Pictures and Videos 8 01-26-2005 09:52 AM
06:13 AM
