Clutch questions - Mustang Evolution
Old 12-23-2014, 02:56 PM   #1
Varasios's Avatar
Clutch questions
Car I have is a 95 gt.
Engine is being rebuilt so I'm changing the clutch while I'm at it aswell.
-The transmission is a tremec t56.
The clutch cable is deteriorated and needs to be replaced. Which is the best choice? MUSTANG MAXIMUM MOTORSPORTS CLUTCH CABLE, QUADRANT, & FIREWALL ADJUSTER KIT (82-04) ?
Also which clutch would you guys recommend for a street car?
-The shop I'm getting all my work done at suggested to possibly swap to a hydraulic clutch setup.
Any input is great guys. Thanks for the read.
Varasios is offline   Reply With Quote
Old 12-23-2014, 11:08 PM   #2
smurf stang's Avatar
A hydraulic clutch is nice but it will be 3 times the money or more.
Now how much hp/tq is your combo going to be putting out? That will decide what clutch will be in your future.
2016 VW GTI 2.0 Turbo
Old 12-24-2014, 12:40 AM   #3
Varasios's Avatar
I would say around 330 to 400rwhp if I'm lucky.
It's a 93 block
The engine is getting a stroker package but isn't being pushed to the ragged edge at all.
Not sure which cam they're using but I've been told it's mild for the street,
Not a letter cam
Getting performer heads cleaned up.
Using Trick flow street heat intake.
Old 12-25-2014, 09:16 PM   #4
Performer heads 1.90 or 2.02 ?
Also that street intake is gonna hold ya back some.
A spec 2 is a nice clutch.
Sent from the Bathroom
Old 12-26-2014, 11:10 AM   #5
Street heat is fine, those heads only flow 230 cfm or so. Don't convert to a hyd setup that is a waste of money. The mm kit is perfect. The exedy mach 400 is a real good clutch for not going over stock block power.
Old 12-26-2014, 08:10 PM   #6
Yeah Scotty but he is gonna stroke it so there will also be some good down low torque. Plus that intake is a killer of power on a stroker as well as the GT40.
Old 12-26-2014, 11:36 PM   #7
If he is using Performers, they only flow 230-240cfm which is less than a ported GT40. He is bottlenecking the motor with those heads and what might be a too small cam (unknown) so there is no reason to go with a crazier intake than a ported GT40. The Mach 400 in the 10.5" size is good for around 450ft lbs. He'll be well under than without a power adder.
For a 331 or 347 stroker, the ABSOLUTE MINIMUM head should be an AFR185 or TFS 190. Those Eddys will flow less than an AFR 165 or TFS 170... And I'm not bashing the Eddy Performer heads, I had a set once myself. They're good heads on a 302 but not anything bigger. If you want Eddys on a bigger motor you jump up to the Victor Jrs and larger.
Old 12-27-2014, 12:59 PM   #8
Varasios's Avatar
Good info guys, I appreciate it. I know it probably doesn't make a whole lot of sense to use those eddys, and that intake with this rebuild I'm having done.
Parts I've had from the past, I have a Eddy upper and lower intake as well but you can definitely tell the ports are small on that rather than the trickflow sh
Maybe I shouldn't of paid the extra$ to do the stroker package for such a mild kind of setup,
The motor needed a rebuild regardless though.
In the future least there's room for a bit more performance if I ever want to spend more hard earned $ lol.
Old 12-27-2014, 09:05 PM   #9
Well then you will have a good base for when money arises. Do what the budget allows.
Old 12-27-2014, 09:55 PM   #10
I would have just found the lowest mileage explorer motor I could, swapped all my stuff over and sold off the GT40 stuff to make my money back. Probably could do a replacement motor for free that way.
Old 07-15-2015, 09:20 AM   #11
Varasios's Avatar
Name:	ImageUploadedByMustang Evolution1436973537.481588.jpg
I know Scotty why all that money into a 302 block
Just sorted out cooling trouble
Getting dyno tune very shortly
Old 07-15-2015, 09:45 AM   #12
That and putting a B cam in a 347? Um... Smh...
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-15-2015, 12:26 PM   #13
Varasios's Avatar
Indeed I hear yah,
For a street convertible that's gonna be a lifer , plenty of torque for me
I guess if I need more power I could ditch the b cam and heads and step it up but I don't see that happening
At the end of the day as long as it's reliable I am a happy camper
Old 07-15-2015, 03:08 PM   #14
Varasios's Avatar
What's the minimum size injector you'd run with this?
Old 07-15-2015, 07:15 PM   #15
A B can is marginal at best for a decent breathing 302 so for a 347 you will definitely need way more cam. A custom cam is just a few bucks more and it will give you better driveability and also more power. Win Win in my book.
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 06:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 07:22 PM
08:12 AM
