Setup question - Mustang Evolution
Old 12-25-2014, 09:33 AM   #1
Shifty 5.0's Avatar
Setup question
The list of mods I have are stock bottom end 302 with twisted wedge heads, 1.7 roller rockers, hardened pushrods, ford racing lifters, e or b cam, under drive pulleys, 255 Lph fuel pump, stage 1 clutch, 4.10 gears, short throw, sub frame connectors, drag shocks, 24# injectors, CAI, 75mm throttle body, bigger radiator, and GT40 upper and lower intake. My question is is what intake could I swap to see a big jump in power? Like the edelbrock or TRICKFLOW intakes?
Shifty 5.0 is offline   Reply With Quote
Old 12-25-2014, 09:18 PM   #2
smurf stang's Avatar
Holley intake is a great one.
Also that letter cam ain't doing you any favors.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 12-25-2014, 09:21 PM   #3
Shifty 5.0's Avatar
Well the only thing I'd switch out at this point is the intakes lol because either ima get a different motor or sell this car and get a new 5.0
Old 12-25-2014, 09:23 PM   #4
Rapinator126's Avatar
LS swap
Old 12-25-2014, 09:31 PM   #5
Shifty 5.0's Avatar
If I did the motor swap I'd do a 408, but for that kind of money in more leaning towards on getting a 13-14 mustang
Old 12-26-2014, 05:11 PM   #6
Go pick up a gt40/explorer lower from a jy or ebay and then send it out to Tom Moss for porting. Will flow 250cfm which what the tfs heads flow and you keep the awesome street characteristics of the gt40.
Old 12-26-2014, 08:13 PM   #7
Well he has the GT40 intake but like I said letter cams are meh. But like Scotty said have them bad boys ported.
Old 12-26-2014, 11:27 PM   #8
Yes he does have the GT40 but pulling an explorer lower out of a JY or off ebay to be ported will allow him to swap the same day and not have weeks of downtime waiting for the portwork to get done.
The letter cams are decent. Not great but they do make power and they sound awesome. A b or e cam and GT40s/GT40 intake and a supercharger is a 450whp motor that sounds ridiculously good. They are all over the place used for $100 but for the same money you can find a near new TFS1 cam which is a little better. The Steeda 19 and the Crane 2030/2031s are also really good for a mild build on the cheap.
Old 12-27-2014, 01:55 PM   #9
WhiteCobra94's Avatar
Upgrade your 24lb to 30lb injectors and put your stock pulleys back on
Old 12-27-2014, 08:52 PM   #10
No need for 30's.
Old 12-28-2014, 08:14 AM   #11
Well with my setup my 24lbs were maxing out at 4,800 RPMS , changed to 30lbs and they took me up to 8,000 RPMS before they maxed out
Old 12-28-2014, 09:14 AM   #12
What mods do you have to be maxing out 24's?
Seen a few 302's put down 320 to the wheels and 24's were still fine.
Also how are you spinning up to 8k?
Old 12-29-2014, 01:15 PM   #13
- 308 shortblock
- Edelbrock RPM heads ported / polished
- Edelbrock RPM intake ported / polished , inlet ported to 75mm
- trick flow stage 2 Cam
- 1.7 rockers
- 75mm throttle body
- JLT CAI
- Full Off-Road Exhaust
TRANS:
- PA racing TRANS
- B&M hole shot 3,300 stall Torque Converter
- 4.11 gears
Had car dynoed at 2nd Street Speed in PA
First set of tuning my 24s were maxing out at 4,800.... 2 weeks later was able to get 30lb injectors and a new MAF
Car dynoed @ 328 rwhp / 321 tq
The power curve dropped off at 7,800 RPMs
Name:	ImageUploadedByMustang Evolution1419883765.813996.jpg
ID:	172577Click image for larger version
Name:	ImageUploadedByMustang Evolution1419883784.013332.jpg
Old 12-29-2014, 03:29 PM   #14
I don't see that combo running up to 8k specially with a TFS2. Would love to see that graph.
Old 12-29-2014, 04:59 PM   #15
I'll get it on here
Old 12-29-2014, 07:24 PM   #16
I'm sorry I was wrong it wasn't 4800 RPMs it was 5276 RPMs where my power curve dropped and I was told to upgrade my injectors . I had this done back in April 2012.
Name:	ImageUploadedByMustang Evolution1419906226.995755.jpg
ID:	172596Click image for larger version
Name:	ImageUploadedByMustang Evolution1419906256.945714.jpg
Question about staggered setup KARgt13 Mustang Wheels & Tires 4 12-17-2012 12:15 PM
Setup Question Stang23 2005-2010 Mustang GT 0 06-26-2011 03:05 PM
Finally got tha setup but got a question Joshs00stang 1996-2004 Mustang GT 12 06-01-2005 07:00 PM
Sold My Nitrous setup Danger Dude The Bar 10 09-22-2003 07:52 PM
Best Dual setup? 6erstang Pre-2005 V6 Mustang 10 09-04-2003 12:54 PM
05:14 PM
