Wheel spacers? - Mustang Evolution
Old 12-27-2014, 07:31 PM   #1
hd85's Avatar
Wheel spacers?
Hi im thinking about picking up some hubcentric wheel spacers. Anybody have them? Are they worth the money? Thanks.
Sent from my SM-N910V using Mustang Evolution mobile app
hd85 is offline   Reply With Quote
Old 12-27-2014, 07:52 PM   #2
mazen123's Avatar
For 1994-2004 mustangs, the front axle is 1 inch wider on each side than the rear axle. Check it out yourself, its obvious looking at the wheels. The rear wheels are tucked in the fender while the front are popping out a bit. I have 275s on my 04 v6 and the rear is still tucked too much for my liking. I will be investing in 1 inch spacers soon, then ill finally get that mean stance every sn95 deserves, you should do the same
mazen123 is offline   Reply With Quote
Old 12-27-2014, 08:24 PM   #3
hd85's Avatar
Yea i lm running 315's on the rear and its still tucked as well. they also rub a little when i go over dips/ curbs because i didnt do the quad shock flip. Would wheel spacers help them not rub as much since the wheels are out farther? Or do i just need to do the quad shock flip?
Old 12-27-2014, 11:02 PM   #4
Just do the quad shock flip, no need for spacers. 315s on a 10 or 10.5" rear rim should be about flush with the fender.
Also have to keep in mind that different years have different width rear axles and fender flares etc... 99-04 cars have 1" wider rear axles than the 94-98 cars, the 99-04 cars also have the built in flares so running a little wider up front does not lip out past the fender and look bleh. There are export fender flares for the 94-98 guys if you can find them but they are a bit of a trick to hunt down.
Old 12-27-2014, 11:29 PM   #5
335s on the rear of a 99-04 are perfect. If you want to do custom flares on the rear end 345+ is possible.
Old 12-27-2014, 11:35 PM   #6
Rapinator126's Avatar
Mini tub
Old 12-27-2014, 11:38 PM   #7
hd85's Avatar
My car is a 94 and im really just looking for a more aggressive stance than i have. I was wondering if spacers worth buying and also if it could help my rubbing problem. But im gonna look into doing the shock flip now.
Old 12-27-2014, 11:40 PM   #8
A more aggressive stance is going to come from wider wheels. And by the looks of that picture you won't have any rubbing issues at all, now lowered enough.
Old 12-27-2014, 11:42 PM   #9
Wider wheels and lowering it makes an amazing difference
Name:	ImageUploadedByMustang Evolution1419745337.193216.jpg
285s btw ^ 305s are coming soon.
Old 12-27-2014, 11:43 PM   #10
hd85's Avatar
my wheels are already 10.5 inch wheels i just wanna be able to see the meat of the tire more.
Old 12-27-2014, 11:47 PM   #11
hd85's Avatar
Attachment 172538
Would flipping the quad shocks allow me to lower it without any rubbing?
Old 12-27-2014, 11:48 PM   #12
Just take them out. Unless you do any real performance driving they won't matter.
Old 12-27-2014, 11:50 PM   #13
hd85's Avatar
Alright thanks for the info
Old 12-28-2014, 10:17 AM   #14
Yeeesh that needs to be lower. Spacers are not needed your wheel is already in a good spot. Just flip the quads and that should cure the rubbing issue. Then springs and shocks and cc plates and some list control arms.
wheel spacers (adapters) OXstang11 Mustang Wheels & Tires 9 10-28-2005 12:42 PM
2 H&R 1" Wheel Spacers 5x114.3 tedness Mustang Parts for Sale and Wanted 6 10-19-2005 12:42 AM
wheel spacers own you tedness The Bar 22 04-21-2005 02:14 PM
Wheel Spacers 19ClearCobra96 1996-2004 Mustang GT 3 11-21-2004 04:18 PM
1.25" wheel spacers!!! a1yola Mustang Parts for Sale and Wanted 10 03-01-2004 06:53 PM
07:28 AM
