Another AODE Shifting Problem - Mustang Evolution
Old 01-03-2015, 12:52 PM   #1
Hello all!
I've recently acquired a 1995 GT that seems to be in pretty good condition other than a couple of problems. The first problem is that it shifts oddly.
When cold it won't shift into gear. After about 30 seconds to a minute it will. If you rev the car for a bit it will shorten this duration. For the next few hours (4-5) it can be turned off and goes until gear just fine.
It shifts upwards into gear fine 1-OD but downshifting seems to happens very noticibly. Enough that coming to stop signs make me put the car into neutral more times than not. This happens regardless of cold.
The tranny fluid seems to be at the proper level, red and supposidly was changed last year.
The car has about 108k miles on it.
I've read quite a bit but nothing that I could find seemed to match my problem.
Any help would be greatly appreciated!!
Thank you
-Mat
UnknownIPandID is offline   Reply With Quote
Old 01-04-2015, 03:50 PM   #2
It sounds like you might need to have that transmission rebuilt. Its failure to go into gear when it's cold is indicative of the transmission not building enough fluid pressure.
Take it to a reputable transmission shop in your area for a diagnosis.
Old 01-06-2015, 07:58 AM   #3
Beau_123's Avatar
It could be your speed sensor
Beau_123 is offline   Reply With Quote
Old 01-06-2015, 09:12 AM   #4
I'm aware that it might be due for a rebuild just wanted to see if it were something simple like a sensor or something. Maybe valvebody?
And why might it be vss? Abs is there anything I could do to test that?
Should I just change the fluid and filter in the the tranny and tc? I'm not sure if the tc fluid was changed recently.
Thank you for all the help!
Mat
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
Another day, another problem SixBanger General Mustang Discussion 69 03-05-2014 11:40 AM
shifting problem? black bullet 1979-1995 Mustang GT 10 12-18-2010 03:01 PM
AODE shifting too early randyrobertson 1979-1995 Mustang GT 2 07-04-2010 12:30 AM
aode problem dbiser 1979-1995 Mustang GT 6 12-30-2007 12:11 PM
07:22 AM
