89 mustang no power - Mustang Evolution
Old 01-03-2015, 04:05 PM   #1
Vazqueza90's Avatar
89 mustang no power
So my 89 stock mustang has lost power I give it gas and it hesitates and when I WOT it only climbs to about 4200 then it pops and the rpms drop back to 3500-3800..
When I give it has the rpms just climb but doesn't move, it pretty much a revs up then it catches
What can it be
Already cleaned maf, IAC, egr(it thru the code saying wasn't opening correctly) going to check timing today
Vazqueza90 is offline   Reply With Quote
Old 01-03-2015, 04:09 PM   #2
Vazqueza90's Avatar
Has no cats
Old 01-03-2015, 04:52 PM   #3
Automatic or manual transmission?
Old 01-03-2015, 05:43 PM   #4
Vazqueza90's Avatar
Manual
Old 01-03-2015, 05:50 PM   #5
When you say "The RPM's climb but it doesn't move". And "Revs up then catches" does it seem like the clutch could possibly be slipping? Or does it seem like the engine is running rough and hesitating?
Old 01-03-2015, 07:04 PM   #6
Vazqueza90's Avatar
Say I'm driving on I just put in second I try to gun it, it revs up to like 2500 then it I feel it catches power again
Old 01-03-2015, 07:42 PM   #7
Does the issue ever get any better?
one day i hope to have something pretty damn witty here
jake01roushv6 is offline   Reply With Quote
Old 01-03-2015, 08:10 PM   #8
Vazqueza90's Avatar
89 mustang no power
Just pulled the codes:
21
33
44
94
Old 01-03-2015, 08:29 PM   #9
P0033?? Are you charged?
Old 01-03-2015, 08:38 PM   #10
Vazqueza90's Avatar
Charged.?
Old 01-03-2015, 08:44 PM   #11
P0033 is turbo bypass valve alarm
Old 01-03-2015, 08:46 PM   #12
Lol nvm. P0033 is not what your getting lol. Code 33 egr fault. My bad
Old 01-03-2015, 08:52 PM   #13
44 And 94
The cylinder heads are either not getting air injected at all from the Thermactor pump or not at the level its supposed to be.
Old 01-03-2015, 09:02 PM   #14
But with three amount of codes here i think the44 and94 are symptoms of other issues that will clear up possibly after EGR issue is fixed
Old 01-03-2015, 09:05 PM   #15
Vazqueza90's Avatar
Charged.?
Old 01-03-2015, 09:08 PM   #16
Vazqueza90's Avatar
89 mustang no power
44 And 94
Where is it.?
what is it.?
how do I test this.?
Old 01-03-2015, 09:09 PM   #17
Vazqueza90's Avatar
I cleaned out the egr but still got the code today
Old 01-03-2015, 09:13 PM   #18
From a dead stop, put the car in fourth gear and rev the engine to about 1800 RPM's, then release the clutch like you would normally do from a stop. If the car starts "bucking" and dies, that's a good thing, your clutch is fine. But if the car tries to start moving and the RPM's don't drop off severely, that's bad. It means that your clutch is worn out.
Those codes are emissions related, it seems, and shouldn't be causing the condition that you described.
Old 01-03-2015, 09:19 PM   #19
Are you over heating at all? Well the EGR code is alarming i believe because its not closing. Possibly torn diaphragm or blocked vacuum line? Can you see the diaphragm on yours? My 2001 is pretty well sealed. But i agree with stray. Test out the clutch but fix this egr related issue soon. If you are indeed climbing revs and going nowhere its most likely a clutch issue. I once had a crx that leaked oil on the flywheel and would do the same thing til she grabbed. That was before i blew the motor and turned it into a mean straight line car with a b16a1....
Old 01-03-2015, 11:13 PM   #20
Vazqueza90's Avatar
89 mustang no power
It kept going😔
Time for a new clutch
Old 01-04-2015, 02:21 PM   #21
Check the fuel pressure. Sounds like a fuel pump going bad.
jdman is offline   Reply With Quote
Old 01-04-2015, 02:40 PM   #22
Vazqueza90's Avatar
How do I do that
Fuel pump is brand new
Old 01-04-2015, 02:50 PM   #23
YouTube it. It's pretty easy and straight forward
Old 01-04-2015, 02:51 PM   #24
Jdman, do you know what the idle pressure should be for the 5.0?
Which has more power and more reliable a '95 5.0L V8 mustang or a '96 4.6L V8 mustang? zachary General Mustang Discussion 6 03-20-2010 12:51 AM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
power mods for 96 mustang.... 96ShowStang 1996-2004 Mustang GT 9 02-02-2007 12:02 PM
Mustang 99 up rear view mirrors power $100 pair Acha3 Mustang Parts for Sale and Wanted 0 08-23-2004 05:50 PM
11:25 PM
