Transmission question - Mustang Evolution
Old 01-06-2015, 04:36 PM   #1
kyle_rivas's Avatar
If I buy just the t5 transmission what else would I need to buy? or recommend? Thanks
instagram @5.0_rivas
kyle_rivas is offline   Reply With Quote
Old 01-06-2015, 05:39 PM   #2
smurf stang's Avatar
What?
What do you have?
What are you trying to do?
2016 VW GTI 2.0 Turbo
Old 01-06-2015, 06:20 PM   #3
kyle_rivas's Avatar
Stock automatic just trying to do a swap
Old 01-06-2015, 06:39 PM   #4
ALMOST STOCK's Avatar
What you need:
- Starter index plate
- Bell housing/scatter shield
- Pivot ball
- T5/T5Z transmission
- Shifter
- Shifter knob
- Shifter weather seal
- Shifter boot
- Flywheel
- Clutch kit (pressure plate, clutch disc, and throw out bearing)
- Pilot bearing
- Clutch fork
- Clutch cable
- Clutch cable clip (secures the cable to the bell housing)
- Pedal Assembly
- Clutch quadrant
- Speedometer gear
- Back-up light harness (Ford part# E7ZZ-15525-A)
- T5 transmission cross member
- Exhaust hanger
Bolts:
- Upper bell housing bolts (7/16" coarse thread 1.5" long, or 1/2" thick spacer/washers)
- Pressure plate bolts
- Starter plate to bell housing bolt
- Transmission to bell housing bolts
Or read theses
AOD to T5 swap procedure - Ford Mustang Forums
WestCoastFords.com
AOD to T5: A 12 Step Program | Shortline Garage
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 01-07-2015, 11:39 AM   #5
kyle_rivas's Avatar
Thanks a lot man
Old 01-13-2015, 12:20 AM   #6
I've read that t5 trans are better when rebuilt but I'm not to sure? Just thought I would let you now
Josueb8 is offline   Reply With Quote
Old 01-13-2015, 08:05 AM   #7
Any transmission is better with a fresh rebuild... not sure why that's even something to bring up lol.
Old 01-13-2015, 12:39 PM   #8
Some guy told me that the t5 is only good for half a dozen runs
But you still don't have to be all rude about it
Old 01-13-2015, 02:16 PM   #9
I'm not being rude at all just pointing out the obvious. Also "some guy" sound like an internet racer...
Old 01-13-2015, 10:00 PM   #10
He may be but he's in this page
Old 01-14-2015, 05:15 AM   #11
Fact of the matter is that a T-5 can hold up just fine for a lot of runs. Depends on the rest of the setup. If someone making 500hp is trying to do 10s on a stock T-5... it may hold for a bit but is living on borrowed time. On my old foxes and my 95 Cobra I beat the living **** out of the T-5s in those and never had an issue. Those were mostly bolt on cars tho.
There is also the A5 which is technically a T5 although all it really keeps from the stock trans is the case and 5/R. And the case can even be upgraded. The A5 is probably THE best manual transmission you can put in a 04-down car.
Old 01-14-2015, 07:33 AM   #12
Back in the 90's I had a bolt on car with a 125 shot that lasted a few years with a stock T5 and a centerforce clutch. I bullied and beat that car and it lasted till "that day". I rebuilt that T5 and it was never the same again. Swapped to an early 3550 and I pretty much hated that tranny so sold it to buy a built T5. Man I should have kept that car.
Almost Stock pretty much outlined what you need. There have been a few guys that put together a package on ebay but it is around 1,500 and up. Maybe if you look on craigslist but it is not a cheap undertaking.
The other thing you never know what you are getting with a used transmission as there is no real way to test them out of the car.
Old 01-14-2015, 09:08 AM   #13
I would never buy a used trans unless it was one that I could test I the car and then watch the guy pull (or help him pull) afterwards.
Old 01-14-2015, 09:37 PM   #14
So untrustworthy LOL.
Used trannies is not something I would bet on.
Sent from the Bathroom
Old 01-16-2015, 07:58 PM   #15
rocknbronco's Avatar
The T5 is in a lot of vehicles too so watch out and if you can purchase a World Class T5, they had higher ratings back in the day if I recall correctly.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
Automatic Transmission Question? TriStateStang Pre-2005 V6 Mustang 10 01-24-2008 12:54 PM
Transmission Question LukeB1034 1996-2004 Mustang GT 1 08-06-2006 09:46 PM
Newbie Question, Transmission? getgo 1979-1995 Mustang GT 8 07-22-2004 01:44 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
05:14 PM
