5.0 timing - Mustang Evolution
Old 01-10-2015, 12:31 PM   #1
jbuhr's Avatar
5.0 timing
i know there are alot of timing threads here but i havent found what im looking for. i have a 95 gt that is giving us hell. at 10 degrees it wont hardly run, it doesnt start to run good until 36 degrees. i have changed the balancer thinking it has slipped but still the same. i got this car ont he cheap and am wanting to get it runnig better. has trik flow heads cam and intake bored .030. any help would be greatly appreciated
jbuhr is offline   Reply With Quote
Old 01-10-2015, 03:13 PM   #2
Beau_123's Avatar
Does it start good when it is cold cause I had a problem with that and found out my battery didn't have enough cold cranking amps.
Beau_123 is offline   Reply With Quote
Old 01-10-2015, 04:33 PM   #3
jbuhr's Avatar
will not start with normal timing just way advanced. wanting to spray it but need to figure out my timing to do so
Old 01-10-2015, 04:52 PM   #4
Liebert91stang's Avatar
Has it ever been tuned after the motor work?
Liebert91stang is offline   Reply With Quote
Old 01-10-2015, 04:54 PM   #5
jbuhr's Avatar
mot tuned yet was wanting to get the timing figured out and another throttle body for it before i took it for tuning.
Old 01-11-2015, 11:55 AM   #6
jbuhr's Avatar
Anyone have any ideas?
Old 01-11-2015, 03:13 PM   #7
You need to have it tuned
Old 01-11-2015, 03:17 PM   #8
Set timing to 12 deg and have it tuned.if not tuned it won't run right.the computer needs to be set up for bore and new h/c/i
Old 01-12-2015, 07:40 AM   #9
smurf stang's Avatar
If the balancer is new then you might have to stab the dizzy again as it might be a tooth off.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 01-12-2015, 02:42 PM   #10
You are pulling the spout when you set the timing right?
Old 01-14-2015, 06:22 AM   #11
jbuhr's Avatar
Yes the spout gets pulled
Old 01-14-2015, 07:21 AM   #12
Read this.....
EFI Distributor Installation and Initial Spark Calibration
Old 01-14-2015, 08:03 AM   #13
jbuhr's Avatar
Old 01-14-2015, 09:36 PM   #14
Read what I posted and restab the dizzy.
Old 01-14-2015, 10:51 PM   #15
This might not make any sense, but it might be your coil. I've seen quite a few cars that had a bad coil, that would still run with extremely advanced timing.
juice_man_86 is offline   Reply With Quote
Old 01-15-2015, 07:45 AM   #16
jbuhr's Avatar
I will try the distributor again to make sure it is right. I can try another coil to see if that is it. Never heard of that before.
Old 01-21-2015, 09:37 PM   #17
Blue skull's Avatar
Is the chain being to loose a possibility? I couldent adjust the timing on mine right because the timing was the original 1990 one lol
Blue skull is offline   Reply With Quote
Old 01-24-2015, 07:38 AM   #18
jbuhr's Avatar
Timing set was supposed to be new. Maybe off a tooth? Work out of town so don't get much time to mess with it this time of year.
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 10:12 AM
Timing question damighty5.0 1979-1995 Mustang GT 12 05-22-2006 04:23 PM
Advancing the Timing Kiljosh Pre-2005 V6 Mustang 4 03-07-2005 10:41 AM
Timing on my blinker is screwed up Seph Pre-2005 V6 Mustang 6 03-28-2004 10:06 PM
Timing Cover Gasket Black95GT Pre-2005 V6 Mustang 3 08-20-2003 08:55 PM
06:37 AM
