What is this? - Mustang Evolution
Old 01-19-2015, 12:13 PM   #1
Living_Legend's Avatar
What is this?
I have it circled in red. I want to order a new one. brittle breaking and all the good stuff.
1990 Ford Mustang GT
5.0L 302Cu. In. V8 GAS OHV (Manual) Naturally Aspirated
Living_Legend is offline   Reply With Quote
Old 01-19-2015, 02:20 PM   #2
ALMOST STOCK's Avatar
That's your EGR with a vacuum hose attached to the 4 port emission block below.
The vacuum hose is hard to find and why more than likely someone use a short piece of rubber hose to couple the 2 ends together.
The original plastic vacuum line has a bulge/bell at the end that fits inside the rubber connectors to keep it from pulling out of the rubber connector.
If you don't have your smog equipment from the smog pump back then you can just cap/plug the other vacuum off leaving the EGR line still hooked up to a vacuum source.
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 01-20-2015, 04:28 AM   #3
Thanks for the info! Very detailed. Is there anyway to know which line does what? One of mine are just cut off and I am not even sure that the ones that are hooked up are hooked up to the right things. I no longer have a smog pump. I have a shorter belt and am without it. The one cut off, should i clamp the end?
Thanks for your help!
Mike
Old 01-20-2015, 09:13 AM   #4
The diagram below will show where al the vacuum line go.
If you're not using a vacuum line then plug it off at the connector with silicon so that you don't have a vacuum leak.
Name:	PLastic Vacuum Line Routing in and out.JPG
Old 01-20-2015, 09:27 AM   #5
You are the man! This is exactly what I needed.
Old 01-20-2015, 12:23 PM   #6
smurf stang's Avatar
Almost has every diagram known to man plus an outstanding member.
By the way, loving the new signature there Almost.
2016 VW GTI 2.0 Turbo
Old 01-21-2015, 08:54 AM   #7
^^^ I don't know about every diagram but I do have a couple.
Thanks ... after being on different Mustang Forums for over 16 years I thought it was finally time to have a signature.
Old 01-21-2015, 11:08 AM   #8
Get some carb cleaner. Get some vacuum line.
Clean the crap outta the motor so you know what you are looking at and to see the condition of things. Start checking for vacuum leaks. Cracked hoses, intake manifold leaks sometimes, stuck EGR valve will be a vacuum leak......they are such sneaky bastards.
Old 01-22-2015, 04:00 PM   #9
You have been a great help. Any chance you have 5 more minutes for me? Mine is a mess. What should I do here?!
I do not have a smog pump anymore or cats.
And is it possible that I don't have a air diverter and air bypass valve? Where and what? Haha. I obviously bought this used and fixed a lot but this has got me stuck.
I ordered this: http://www.ebay.com/itm/321391412666...%3AMEBIDX%3AIT
ID:	174029   Click image for larger version
ID:	174031   Click image for larger version
Old 01-22-2015, 04:24 PM   #10
Old 01-23-2015, 05:08 AM   #11
Liebert91stang's Avatar
I believe they are all different diameters so they will only go to the same port so that should help you out.you can go to any parts store and get hose to fit.
Liebert91stang is offline   Reply With Quote
Old 01-23-2015, 08:36 AM   #12
Your Air Diverter and Air Bypass will be on a formed rubber hose coming out of the back of the smog pump, and my guess is that you don't have them.
You can seal all the vacuum lines that are not in use, what do the long vacuum line go to ?
Name:	Air Pump Back.JPG
ID:	174081   Click image for larger version
Old 01-23-2015, 08:41 AM   #13
the long one is going to the back of the intake mainifold. red wire coming in and black wire coming out.
the middle one is hooked to the EGR which looks wrong when compairing to the diagram, I ordered a used new set from the ebay link above. maybe to start over.
Old 01-23-2015, 08:49 AM   #14
That makes since what the long vacuum line is doing and as far as the EGR vacuum line not being plugged into the vacuum port like the diagram that doesn't matter as long as you have vacuum to that port.
If you don't have the smog equipment you can eliminate all the vacuum lines and that 4 port rubber connector, all you need is a vacuum line from the EGR to the vacuum tube at the back of the upper intake.
Old 01-23-2015, 08:53 AM   #15
Vacuum line routing under the upper intake
Name:	Vac under upper.JPG
ID:	174083   Click image for larger version
Name:	Fuel Pressure Regulator.JPG
Old 01-23-2015, 09:20 AM   #16
mine is a tubular intake. Thanks for all the help. When I get home i need to do some investigating
Old 01-23-2015, 09:47 AM   #17
Originally Posted by Living_Legend View Post
mine is a tubular intake. Thanks for all the help. When I get home i need to do some investigating.
So is mine
Name:	GT 40 Vacuum Routing.JPG
Old 01-23-2015, 10:02 AM   #18
So is mine
I am cool with copying off your Mustang Fame.
Mustang Monthly Magazine - Mustang 360
(Direct Link)
Old 01-23-2015, 12:10 PM   #19
Blue skull's Avatar
Does the fuel preassure regulator have to be hooked up from the intake? My vaccum line to the regulator is coming from else where.
Blue skull is offline   Reply With Quote
Old 01-23-2015, 01:01 PM   #20
As long as the vacuum source is constant you're good to go.
Old 01-23-2015, 01:03 PM   #21
Not a problem copy away.
Old 01-23-2015, 01:09 PM   #22
Blue skull's Avatar
Oh ok thanks man
02:15 PM
