Idling Issues - Mustang Evolution
Old 01-21-2015, 11:40 AM   #1
Cise's Avatar
Idling Issues
So I recently had my Clutch, flywheel, and u joints replaced on my 95 GT, and that solved a world of problems for me, however, I have new ones and I'm kinda stumped. I'm not super mechanically savvy, but I like to figure out whats wrong on my own.
-It's now idling really rough (like it's got a big cam)
-you can smell fumes in the cabin at idle when the heater is on
-You can smell a slight burning smell outside the car after driving
-It kinda seems like it's going through coolant faster than usual
-oil looks fine and not milky
-I noticed one of the tips was a little crooked a day or two ago
- 1st to 2nd gear it kinda falls on its face if you drive spiritly
when I had the trans rebuilt I was also told I might have a small leak on my oil pan, but they weren't sure.
Cise is offline   Reply With Quote
Old 01-21-2015, 01:42 PM   #2
Blue skull's Avatar
Maybe a dirty maf? Or a faulty tps
Blue skull is offline   Reply With Quote
Old 01-21-2015, 02:11 PM   #3
natestang07's Avatar
Check the spark plugs, the check for a vacuum leak
Old 01-21-2015, 06:06 PM   #4
Foxbody91's Avatar
Does it have a hard time starting up? And while idling does it cut off?
Foxbody91 is offline   Reply With Quote
Old 01-21-2015, 08:54 PM   #5
smurf stang's Avatar
Have you run your codes?
So your losing coolant?
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 01-22-2015, 11:03 AM   #6
Cise's Avatar
It is flashing the CEL (on and off quickly) but not long enough to catch a code, and unfortunately I don't have a tuner (went to autozone to try and get a code). It doesn't have any trouble starting up, and does not cut off. Regarding the coolant. It doesn't seem like it is, but it started spewing white smoke and it turned out it drank all the coolant, but it hasn't done that again, and the coolant seems to remain at normal levels.
Old 01-22-2015, 11:52 AM   #7
Pull your codes for free.....
http://sbftech.com/index.php/topic,2471.0.html
Here is what they mean.....
http://sbftech.com/index.php?PHPSESSID=7261a4935687afe79b81c982b1b049ec&/topic,849.0.html
If it drank all the coolant then it is being burn or spit out somewhere either a head gasket or intake gasket.
Idling Issues KARgt13 2011-2014 Mustang GT 19 01-05-2013 07:49 AM
Idling too low katie_ann 1996-2004 Mustang GT 9 09-02-2009 03:42 PM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 08:29 AM
!Help! Engine Idling and Rev Issues 06v6stang Pre-2005 V6 Mustang 5 08-08-2008 07:12 AM
Help Needed In England - Idling Problem glenheyes 2005-2010 Mustang GT 11 04-21-2008 03:08 PM
11:23 PM
