Clutch to use with supercharger - Mustang Evolution
Old 02-18-2015, 10:11 PM   #1
Shifty 5.0's Avatar
What clutch would I need for my supercharged application? People throw supercharger kits on their cars all the time with stock everything but fuel system and run fine but iv seen people blow clutches with supercharged 302's on like 1-2 passes
Shifty 5.0 is offline   Reply With Quote
Old 02-19-2015, 12:24 AM   #2
irishn8's Avatar
Id say stage 1 would be adequate, stage 2 would be safe with room to grow
Old 02-19-2015, 07:36 AM   #3
Shifty 5.0's Avatar
I have a stage 1 now but on the american muscle fox they blew their stage one on the second pass after they supercharger that convertible lol but then I see people running all stock with a super charger
Old 02-19-2015, 09:48 AM   #4
"Stage" literally means nothing dude, its a marketing thing for ppl who are too lazy to read the actual clutch specs and ricers. You go buy the manufacturer's torque rating.
AM has the manufacturer's ratings on their clutches right in the item description. The Exedy Mach 400 is rated at 438ft lbs at the flywheel, the McCleods are a little more.
You can always look into ceramic clutches too but those have a different feel to them and not everyone likes them.
Old 02-19-2015, 11:25 AM   #5
Shifty 5.0's Avatar
So what's your thoughts on this? Click image for larger version
Name:	ImageUploadedByMustang Evolution1424370302.709815.jpg
ID:	175723Click image for larger version
Name:	ImageUploadedByMustang Evolution1424370315.726339.jpg
Old 02-19-2015, 06:05 PM   #6
UPR cable is garbage and they are flat out lying about the HP capability of that clutch. Also the real "King Cobra" is discontinued so that is whatever they are sourcing for a 10.5 organic clutch.
Get the Exedy Mach 400, get an OEM pilot and OEM TOB and get the Max Motorsports quadrant/firewall/cable kit.
Old 02-19-2015, 06:44 PM   #7
Shifty 5.0's Avatar
So you think that clutch would be good for a supercharged H/C/I 302?
Old 02-19-2015, 06:45 PM   #8
The Exedy Mach 400? It will be right on the edge. So will the T-5Z you installed though. The Z spec is a little stronger but the stock third gear will still be the "glass jaw" you'll need to worry about.
Old 02-19-2015, 06:57 PM   #9
Shifty 5.0's Avatar
Yeah now I'm more looking to the exedy 500. How's come so many people run the cars mostly stock and still able to run it? Just no hard launches?
Old 02-20-2015, 07:25 AM   #10
That's a ceramic clutch and will behave differently than an organic. More potential chatter and much quicker engagement. Some ppl like it some don't.
Old 02-20-2015, 08:02 AM   #11
Shifty 5.0's Avatar
All I'm worried about is the strength of it for now. Thanks for all the info
Old 02-20-2015, 11:58 AM   #12
Like I said the Mach 400 should be fine unless you plan to launch it on slicks or drag radials at the track which I would not do without upgrading the trans to something stronger anyway. Street tires it will be fine.
Old 02-20-2015, 02:02 PM   #13
smurf stang's Avatar
Plus if you want to stay with easy drivability organic is the way to go.
2016 VW GTI 2.0 Turbo
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
What would i need to do to my 5.0 302 engine so i can use a centrifugal supercharger? Haav 1979-1995 Mustang GT 3 06-27-2012 11:00 PM
I have a 1988 Mustang that is putting out about 400 horsepower. Can I use a dual-disk clutch in it? jeffery 1979-1995 Mustang GT 2 12-21-2011 01:05 AM
Can I use a Ford Racing steel flywheel with a Centerforce clutch kit? Finian 1996-2004 Mustang GT 2 12-15-2011 09:47 AM
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 08:19 AM
11:28 PM
