Isolated starting problem - Mustang Evolution
Old 02-23-2015, 04:20 PM   #1
surfinglbi23's Avatar
Hey guys - having a starting issue I need to isolate. 1994 GT 5.0, fresh tune up, 150k miles. When the car is cold, ie., sat for a day or so. I have had this issue since I owned the care where if I get in and crank the car it would crank for a solid 30 seconds before starting.
However, I cheat this by cranking it for about 3 seconds and then stopping for a good 10-15 seconds. By this time, it will crank and instantly start. So the issue hasn't bothered me but its time to get to fixing it. No issues when the car is warm.
So, I am thinking my fuel pump is losing pressure? Any ideas how to confirm my issue? Would like to order parts this week and knock it out his weekend while I have some time.
surfinglbi23 is offline   Reply With Quote
Old 02-24-2015, 08:09 AM   #2
Check your pressure at the rail with a pressure gauge. When was the last time you did the fuel filter?
Old 02-25-2015, 08:46 AM   #3
I did the fuel filter in November. Have barely put 500 miles on the car since then. I'll check the pressure at the rail. What is the range I'm looking for and what would low pressure indicate?
Old 02-26-2015, 06:26 AM   #4
IIRC its 40psi with vac off but double check, I have not messed with a pushrod since like 2009...
95 5.0 starting problem stangrunner 1979-1995 Mustang GT 27 09-13-2011 08:48 PM
2011 GT Random starting problem ray bouquet 2011-2014 Mustang GT 5 02-16-2011 04:23 PM
03 starting problem GatorBen Pre-2005 V6 Mustang 3 07-22-2010 07:47 PM
Starting problem bobroloff 1996-2004 Mustang GT 6 07-18-2008 10:49 AM
Weird starting problem... lowflyn Pre-2005 V6 Mustang 13 10-28-2005 08:20 PM
05:31 AM
