Stock fox body - Mustang Evolution
Old 03-09-2015, 03:43 PM   #1
kickerofdoom's Avatar
Stock fox body
If you got a stock fox body what would you add to the car
Old 03-09-2015, 05:42 PM   #2
Roguestang's Avatar
I did have one, and I did some of the suspension first. Lowering springs, subframe connectors, and tubular control arms. Handled like a new car. Then I put a vortech in her
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 03-09-2015, 05:49 PM   #3
Ubnbit's Avatar
Pics please!
Old 03-09-2015, 05:56 PM   #4
Name:	ImageUploadedByMustang Evolution1425945393.504054.jpg
Old 03-09-2015, 06:01 PM   #5
I put a hurst billet plus short throw,up grade to msd cap/rotor, wires, new plugs, /tune up, soon to be msd 6al-2, for better spark, a rev limiter and 2 step. A fuel gauge on the rail. Just a few things to make it run better. Next would be bushings, suspension. My route is to make a
Nice Driver. My last one was
A 88 notch, went all performance.
FX4L is offline   Reply With Quote
Old 03-09-2015, 06:03 PM   #6
Name:	ImageUploadedByMustang Evolution1425945757.484874.jpg
ID:	177060 my current 91 lx
Old 03-09-2015, 06:13 PM   #7
Ubnbit's Avatar
Originally Posted by kickerofdoom View Post
Attachment 177055
I love it bro! I wish I had your problem lol. Where to begin.
Old 03-10-2015, 08:33 AM   #8
Senior Member
Otroo's Avatar
I would do heads,cam and intake on it.
Otroo is offline   Reply With Quote
Old 03-10-2015, 08:42 AM   #9
Having had a 88 GT when it first came out, I found the best things to do with an older one, is chassis and suspension reinforcements, before adding power. Check the torque boxes, and the rear upper control arm attaching points to the floor of the car, and subframe connectors, before adding power.
DeepImpactPony is offline   Reply With Quote
Old 03-10-2015, 10:59 AM   #10
Gt40 kit, cam, headers, enough said...
Adventure till you drop
Old 03-10-2015, 12:02 PM   #11
Shifty 5.0's Avatar
If I could go back to when I first got mine I would of just immediately done the 351 swap. Easy power and tons of room to grow
Shifty 5.0 is offline   Reply With Quote
Old 03-10-2015, 12:57 PM   #12
ALMOST STOCK's Avatar
1st thing ........ upgrade those factory brakes.
If you can't stop it then there isn't any reasons for the mods mentioned above!
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 03-11-2015, 08:14 AM   #13
smurf stang's Avatar
If I had that mustang the first things I would do is go through the brakes (completely), bushings, suspension parts and chassis. I would get her road worthy and tip top.
Spend countless nights wondering which direction I wanted to spend all my money.
351 swap would be the foundation for sure but that is just the very tip of the iceberg.
2016 VW GTI 2.0 Turbo
Old 03-11-2015, 06:33 PM   #14
Panther140's Avatar
I would make sure its reliable first and foremost. Like, daily driver reliable. I would go through and fix/replace any little issue on the car.
First aftermarket thing I would do is add a stage 2 cam to get that awesome sound of a cammed 5.0 and a little more power.
Then I would focus on handling until it was auto cross quality.
Then nitrous.
Then get some more CC heads.
Panther140 is offline   Reply With Quote
Old 03-12-2015, 06:18 AM   #15
"Stage 2" cam won't do **** with stock heads and likely won't clear the valve reliefs. Been there, done that.
Old 03-12-2015, 06:23 AM   #16
Best bet for a Fox is to go to a jy, yank some gt40s out of an exploder take them to a shop for a quick clean/valvejob/springs and swap them on with the exploder intake. Stock tune will not have to be touched. Longtubes and full exhaust while heads are off. Then suspension all over, brakes, chassis bracing, other basic bolt ons and finally a vortech and a tune.
That is the budget way to do it and hope the t5 trans holds. For a 351 swap... Might as well do a 408 which is going to be $6-$8k for the motor alone lol.
Old 03-12-2015, 09:01 AM   #17
Or just slap a 460 in there and be with it.
Old 03-12-2015, 06:56 PM   #18
460 foxes are cool as hell. Be prepared to spend $25k+ on the build alone though.
Old 03-12-2015, 07:38 PM   #19
No one would add a 351 and turbo ?
Old 03-12-2015, 09:02 PM   #20
Why would you need to? Unless you are doing an all out drag car. A mild 408 will do 500/500 on pump gas all day and it'll have a ridiculous powerband.
Honestly nowadays the Coyote swaps are becoming real popular in everything and IIRC On3 Performance has a twin turbo kit for the Coyote modified to fit in the fox if you call them direct you can get it. That's probably the way to go with a turbo app.
Old 03-13-2015, 11:54 AM   #21
Or do a budget 302 with a used supercharger kit found on craigslist.
Old 03-13-2015, 02:18 PM   #22
This is what I will do if I ever get another pushrod. And that would only be a 94/95 Cobra. Usually will be much better kept than their GT counterparts and come with a set of heads/intake that actually flows a half decent amount of air (200 cfm stock).
Then yes, a used Vortech in good shape from a forum classified for $1500, bolt ons and a tune and 425-450 safe rwhp all day and 24mpg on the highway.
Old 03-13-2015, 09:29 PM   #23
All day every day.
Sent from the Bathroom
Old 03-20-2015, 02:47 AM   #24
mike s's Avatar
I'm in the same boat... About 3 weeks ago I picked up a bone stock lx convertible. This is fox #12 for me in my life but I'm still very undecided which direction I want to go. It has been a long time since I have seen a fox still have smog pump, air silencer, all cats and even stock mufflers lol. It is completely untouched and only has 71k miles on it. Click image for larger version
Name:	ImageUploadedByMustang Evolution1426841215.289329.jpg
mike s is offline   Reply With Quote
Old 03-20-2015, 09:56 AM   #25
She is a beaut.
Old 03-20-2015, 12:42 PM   #26
mike s's Avatar
Thanks she needs a lot but will be a fun project
Old 03-20-2015, 08:21 PM   #27
Gorgeous and a vert. I will say that fox verts have a front and rear bumper that were separated at birth and are forever trying to get back together. About the first thing I did on any fox I ever had was subframes if it didn't have them already.
Old 03-22-2015, 06:14 PM   #28
Vicious5.0's Avatar
After wrecking my 98 supercharged cobra. I got me a 89 gt conv. I have spend waaaayyy less money on upgrades then i did with my 98. And i love the fox body much more.
Vicious Mustang: Racing aluminum heads. Professional products lower and upper intake. 75mm throttle body. trickflow stage 1 cam. PYPES headers, h pipe, exhaust. T5z transmission. Spec stage 1 clutch. 4.10 gears. Tubular lower control arms. Powerdyne supercharger 42lb injectors @9psi.
Vicious5.0 is offline   Reply With Quote
Old 03-22-2015, 06:14 PM   #29
Vicious5.0's Avatar
Name:	ImageUploadedByMustang Evolution1427069689.181961.jpg
Old 03-22-2015, 08:41 PM   #30
That's because it was a modular and a B headed 4V to boot. The pushrods are nice and cheap though, honestly I like the 94/95 cars, best of both worlds and the 94/95 computer that ppl always complain about is an easy fix.
fox body
Body kit on Fox body MustangMitch50 1979-1995 Mustang GT 3 09-18-2014 08:23 AM
99-04 gt stock throttle body and stock pulleys fultonboy09 Mustang Parts for Sale and Wanted 3 08-09-2012 10:50 PM
cheap fox body body panels Jonnyfast89 General Car Discussion 2 04-22-2011 03:02 PM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
BADASS VIDEO... 03 cobra vs modded fox body and modded SS... Zim The Bar 5 07-24-2003 11:54 PM
04:20 AM
