Project Swampfox - Mustang Evolution
Old 03-15-2015, 03:53 PM   #1
TwoWhiteGirls's Avatar
Project Swampfox
Just picked up the car I've been chasing for the past 4 years. 1991 5.0 notch. Originally a Florida car I hauled it up to VA where I live and shes finally in my garage and ready to rock. Only problem is this is my first american car let alone Mustang. I'm a VW/Audi vet. I'll be needing you alls expertise when it comes to me learning what the hell I'm doing lol. In a way I lucked out as I'm already working with a decent platform as far as the drivetrain is concerned. It just needs tlc on the body due to some Florida rust. I also plan on ripping the interior out and doing a stock black interior.
Here's a list of the mods as they've been explained to me.
-stock block bored 40 over
-308 cubic inch
-7000 rpm balanced crank
-Edelbrock aluminum heads
-Edelbrock upper/lower Performer
-RPM 2 intake
-574 lift Trick Flow cam
-eagle rods
-SRP pistons head studs
-BBK equal length shorty headers
-MAC prochamber
-cat delete
-40s flowmasters
-MSD billet distributor and
-6al ignition box
-Click image for larger version
Name:	ImageUploadedByMustang Evolution1426456369.279427.jpg
ID:	177511266 litre fuel pump
-Paxton SN 2000 supercharger
-76 mm c&l mass air flow
-24 pound fuel injectors
-holly throttle body
-Umi adjustable drag link
-rear spec 3 clutch and pressure plate
-hurst short shifter
-new clutches in rear with 1extra forced shim
Anyone have any input on this setup or any of the components. I drove it a little bit. It's scary quick. Not used to smoking tires through 3rd gear at 3K.
Hope you guys join me on this build journey.
TwoWhiteGirls is offline   Reply With Quote
Old 03-16-2015, 10:43 AM   #2
smurf stang's Avatar
Well it seems like you have a good platform to work with.
One concern is the fuel injectors. They are on the small side....what are you using to increase the fuel pressure with the boost? A FMU?
Also that cam is not ideal for boost either.
2016 VW GTI 2.0 Turbo
Old 03-16-2015, 02:05 PM   #3
Project Swampfox
Yes he gave me a FMU in a box that increases fuel at a certain boost, he said he removed it due to it not being necessary for the type of driving he was doing. I'm not sure what type it is but I will start throwing up pics of the motor and additional components I have. What type of cams are solid for that type of setup?
Update on project "Big Block Six" plstktnkr2 The Bar 16 03-21-2006 08:18 AM
We have the Cody Project! Dom The Bar 9 12-17-2003 03:29 PM
my physic project :D fast64 The Bar 2 11-06-2003 02:55 PM
my new project car SixshootaPB The Bar 24 08-17-2003 08:23 AM
A New Project Dan The Bar 12 07-29-2003 08:56 PM
04:42 PM
