Would 1.7 rollers on gtp heads cause issues? - Mustang Evolution
Old 03-21-2015, 11:24 AM   #1
95gtnewb's Avatar
I'm trying to go full roller rocker. But would lash on pushrods be an issue?
Sent from my XT1031 using Mustang Evolution mobile app
95gtnewb is offline   Reply With Quote
Old 03-21-2015, 08:02 PM   #2
If the valves are stock they should clear just fine with most milder cams. You will want to check for proper witness marks though. Install a solid lifter under one of the pushrods and do the pushrod length check thing and make sure. If not then you can try to use the pedestal mount shims to correct or you may need a different set of pushrods.
Rollers 5.oh 1979-1995 Mustang GT 2 10-05-2013 02:39 PM
98 v6 what would cause.... Wildone Pre-2005 V6 Mustang 8 01-10-2013 01:44 PM
Anybody know much abot a 5.0L GTP motor? Blacksmith The Bar 7 01-06-2013 05:19 PM
The vandalized GTP.. MonteCitan The Bar 5 08-27-2005 01:50 PM
Ford Mustang Probe GTP .:DarkEntity:. The Bar 15 10-03-2003 05:49 PM
07:56 PM
