Transmisson problem - Mustang Evolution
Old 03-22-2015, 01:56 PM   #1
Shifty 5.0's Avatar
Transmisson problem
I just installed a new pilot bearing,clutch,flywheel, and throwout bearing and when I go to put the Trans in it goes all the way in except for like 3cm and I know you're not suppose to bolt it in if its not sitting flush with the bellhousing but I can't figure out why it won't go in the few can!
Shifty 5.0 is offline   Reply With Quote
Old 03-25-2015, 06:46 AM   #2
It'll go in. You did use the clutch alignment tool right? And when you tigthen the clutch down you need to be constatnly removing and re-installing the tool to make sure it slides right in with no tension on it at all. If you just tighten the clutch down with the tool in place but don't check on that, its probaly going to be bound up and that is causing your issues. Or its soemthing stupid like the wiring harness is falling in between the trans and bell whre you can't see it and boogering it up.
Old 03-25-2015, 10:10 AM   #3
Shifty 5.0's Avatar
I checked to make sure the wires weren't in the way. I'm going to take it out today and make sure the pilot bearing is all the way seated because it's literally a few centimeters that it won't go in 😒
Old 03-25-2015, 12:01 PM   #4
Take a socket and a hammer and put the socket up on it and tap tap taperoo. Also... if this is a rebuilt trans are you sure its not a SN95 input shaft? Those are an inch longer than fox shafts lol. That would suck.
Old 03-25-2015, 03:58 PM   #5
Shifty 5.0's Avatar
It's definitely a fox trans but I'm going to make sure everything is seated and what not because it's really holding up this build
Old 03-25-2015, 09:28 PM   #6
Shifty 5.0's Avatar
So I found out that the bearing retainer shaft is hitting the clutch where the splines go into so that's what is stopping it. But why does it stick out further so it won't go in all the way? It's a spec stage 2 which I know stages don't mean anything it's the torque rating but it's making me mad
changing transmisson fluid Audicrashdummy 2005-2010 V6 Mustang 4 01-11-2013 06:29 PM
Is this bad for my 5 spd transmisson? MachMan1017 General Mustang Discussion 1 09-26-2012 12:08 PM
T5 transmisson. Thrasher13 1979-1995 Mustang GT 5 06-21-2012 04:00 PM
transmisson possible problem a00mustangjk Pre-2005 V6 Mustang 3 09-25-2005 03:41 PM
Transmisson Work in NJ Black95GT Regional Mustang Discussion 4 08-09-2003 01:06 PM
06:29 PM
