Electric problems - Mustang Evolution
Old 03-31-2015, 03:47 PM   #1
kickerofdoom's Avatar
Electric problems
The cars runs fine and the headlights have no problems on at night but the inside the CD player and the battery needle drop when stuff is on. The car has a bigger alt I got the battery and alternator tested but nothing wrong
Old 03-31-2015, 03:57 PM   #2
jhall27's Avatar
Underdrive pulleys? Those will do it. Could also be a loose connection somewhere.
jhall27 is offline   Reply With Quote
Old 04-01-2015, 08:45 PM   #3
wbrockstar's Avatar
I would check all the grounds thoroughly.Pay special attention to the secondary ground(strap between back of cylinder head and firewall.The link below goes into detail about this.Make sure the charge indicated light on the dash comes on momentarily when you first turn the key on.If it doesn't,repair the circuit because a non functional charge indicated light can cause the alternator to not charge.Did you paint the alternator or its bracket by chance??If so,the alternator is case grounded which means it won't be grounded correctly if its not bare metal to metal.Make sure your serpentine belt is tight enough because a worn tensioner will allow too much belt slack causing an under charge condition.
How Important are Grounds in a Ford
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 04-03-2015, 01:06 PM   #4
Foxbodies have VERY weak alternators, barely adequate for a bone stock car. Even if its a "bigger" alt you need to upgrade it to 94-up spec which is called the "3G conversion". Look it up on the interwebs. Fixes a lot of power issues with the foxes.
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
electric water pump? widowvirgin Pre-2005 V6 Mustang 15 07-01-2004 03:30 PM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 07:03 AM
electric shift kit Dave Pre-2005 V6 Mustang 7 08-07-2003 06:00 PM
electric pumps el cheapo Pre-2005 V6 Mustang 4 07-21-2003 11:46 PM
02:36 PM
