Fox is burning through spark plugs - Mustang Evolution
Old 04-03-2015, 12:28 AM   #1
DTA72's Avatar
I've had the car for about 2 years and I've replaced the spark plugs probably 4-5 times. Every time I do it I pull them out and look at them and they look burnt out. the only things I have done to the car are under drive pulleys long tube headers and 8mm plug wires.
I was just driving the car recently when it just shut off and now it only cranks. It gets enough fuel and air could it be my distributor finally went up?
DTA72 is offline   Reply With Quote
Old 04-03-2015, 02:04 PM   #2
Change your entire distributor, coil and TFI module.
2000 Mustang GT Steeda #0048
Old 04-05-2015, 10:07 AM   #3
wbrockstar's Avatar
A bad pip sensor inside the distributer or a bad ignition module is normally what goes out on a distributer.Autozone can test the ignition module if you remove it and carry it in.A tfi socket tool is needed to remove it.The pip sensor can be replaced,but you'll have to remove the distributer gear and pull the shaft out in order to get access to the pip sensor.Some people prefer to just replace the whole distributer instead.The link below will show you how to test the pip and tfi module.Burnt plugs could be due to a weak ignition or an over rich fuel condition.Here's that link.
http://351winsor.com/joel/Ignition_Systems/tfi2.html
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 04-06-2015, 02:32 PM   #4
DTA72's Avatar
Changed out my distributor and two and it started right up. Thanks guys
Old 04-11-2015, 06:42 AM   #5
wbrockstar's Avatar
That's good to hear.Now you'll have more money to buy the next go fast goodie bolt-on since you're not replacing plugs every so often.Thanks for the update.Some people get their problem fixed,but never post what the fix was so it leaves people guessing
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 09:42 AM
No spark in the spark plugs 94GTpony 1979-1995 Mustang GT 7 10-30-2012 02:20 PM
Blow Through vs. Draw Through, HELP!! CodyNelson 1996-2004 Mustang GT 7 01-06-2012 05:26 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 10:45 AM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 04:20 PM
05:35 AM
