Increasing Horsepower on a Budget - Mustang Evolution
Old 04-05-2015, 09:32 AM   #1
What little things can I do to add hp in a cheap way on a 1988 mustang 5.0 gt?
ryan_moran is offline   Reply With Quote
Old 04-05-2015, 05:49 PM   #2
Cheap and performance mods usually don't go together... What budget are you working with? Is your 88 converted to MAF or still speed density?
Old 04-05-2015, 06:38 PM   #3
wbrockstar's Avatar
If you haven't converted to MAF yet,don't change the cam.K&N air filter,under drive crank pulley,shorter belt to bypass the smog pump,adjust timing to 14°(if using 91+ octane fuel)Its not exactly a cheap mod,but its cheaper than aftermarket parts.95-early 97 Explorer GT40 or 97-01 GT40P heads or better yet,69-71 351W heads(must use different headers on the GT40P heads though)95-01 Explorer throttle body,94-95 Mustang 70mm MAF sensor.The link below lists parts you can snag from cars at the junkyard.
Junkyard Horsepower SUMMARY! - Ford Mustang Forums : Corral.net Mustang Forum
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 04-07-2015, 08:38 AM   #4
smurf stang's Avatar
Here's a good little read....
Five.Oh Info : The Foxbody Mustang Specifications Site : Engine, Transmission, Brakes, Suspension & more!
2016 VW GTI 2.0 Turbo
06:56 PM
