Weld-on Full Length Subframe Connectors - Mustang Evolution
Old 04-19-2015, 03:10 PM   #1
RoCoBass's Avatar
Region: Iowa
I have a set of SVE sfc that I need welded on. A local shop quoted me minimum 3-5 labor hrs. I know it won't take that much time, my torque boxes are straight and w/out any rust. I told 'em I'd remove carpet myself and prep surfaces. At that rate I might as well invest in a small used welder. My questions is would a 110v mig put out enough penetration to properly weld the sfc? A buddy has 1 that I can borrow, if not sufficient, I'll look for something bigger. Any tips or advice on the subject would be appreciated, thanks.
Sent from my USCC-C6721 using Mustang Evolution mobile app
RoCoBass is offline   Reply With Quote
Old 04-19-2015, 03:13 PM   #2
I don't have an answer to the actual welding or welder question. But I did them with a friend in his garage and it took about 2-3 hours. That included jacking the car and bracing it to where full load is on the suspension, prepping the SFCs, and painting them afterward. A shop should be able to do it quicker.
Old 04-20-2015, 07:24 AM   #3
RoCoBass's Avatar
Region: Iowa
I agree w/ ya. They'd just have to drive it onto the lift, anchor a ground, tack in place, & go at it. I'd rather install them myself but it'd be quicker at a shop. I guess I'll try to see if another shop will give me a cheaper quote.
Old 04-20-2015, 12:19 PM   #4
Shop around me does it for $400 and that includes the cost of the SFCs as well as a roll on sealer to prevent any corrosion. So if your shop is at $100 per hour and does it in 3 hours and the SFCs cost $120 or so... that's about right. If you are under $100/hr then its definitely spot on.
I'd say that a regular MIG is good but SFCs are really something you want an accomplished welder to be doing with a high quality welder. You don't need the welds to be snapping on you when the body wants to flex and the SFCs are preventing it.
I also prefer Spintech or Global West SFCs for ground clearance or Steedas if you are going to go with a "typical" set.
Old 04-20-2015, 12:48 PM   #5
I have a 120v Lincoln Might welder and it seems like welding thin material is what it is best at, so yes, a 120v will do a good job. However, if you are not a very experienced welder, you should practice on some similar guage metal, and get comfortable with the welder, before working on your car.
Old 04-20-2015, 01:46 PM   #6
Lol you guys should see the knock off fluxcore welder in my garage. Its been 8 years sitting there, I have no idea if it works haha.
Old 04-20-2015, 06:58 PM   #7
smurf stang's Avatar
MM subframe connectors are nice.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 04-20-2015, 07:19 PM   #8
They're good too. But if you live in a state with a lot of speed bumps/humps or potholes you have to watch out a big for "traditional" ones. I know in my old neighborhood I would probably have scraped them on all the speed humps if the 98 actually had them. I never did get around to installing subframes on that car, it had every other "bolt on"... If you look at the Spintech or Global West ones you'll see why they are better for ground clearance and you can even run sidepipes.
Old 04-20-2015, 07:31 PM   #9
I scrape my exhaust before my MM Subframes
Old 04-20-2015, 07:38 PM   #10
Yeah well yours is lowered like 2.5" or some cray cray amount lol.
Old 04-20-2015, 07:52 PM   #11
Exhaust and subframes are both connected to the same point of the car though. So when the car goes down they go evenly. So even if it wasn't lowered that much the exhaust would still be lower.
Old 04-20-2015, 08:31 PM   #12
I guess the exhaust on my Cobra tucked up a little better. The subs were lower, not much but they were.
Old 04-20-2015, 08:43 PM   #13
RoCoBass's Avatar
Region: Iowa
My SFC seem to be low profile and I have way too much ground clearance. Looks like a 4x4, imo! Starting to upgrade suspension but want to start there. I definitely need lowering springs.
Old 04-21-2015, 08:24 AM   #14
Stock suspension on a Mustang looks like a 4x4... its really bad. After you've had a lowered car and are used to the way yours looks the non-lowered ones just look ridiculous.
br/nola: i got some full length subframe connectors, and need help DarkShadows Regional Mustang Discussion 4 06-07-2010 11:12 PM
Subframe connectors Zim Pre-2005 V6 Mustang 15 07-14-2004 11:58 AM
How much to install subframe connectors njstang97 Pre-2005 V6 Mustang 8 02-01-2004 11:42 AM
Subframe connectors? 01mineralgrey6 Pre-2005 V6 Mustang 8 07-22-2003 12:06 AM
11:30 AM
