Trans issues - Mustang Evolution
Old 04-20-2015, 10:08 PM   #1
RaysV6's Avatar
Send a message via Yahoo to RaysV6
Trans issues
Ok so I got another 5.0 motor dropped in, took a trans off a 95 gt that was bolted to a 79 Windsor 351. Installed it on my motor car starts up fine minus a small starter sound. But installed a new clutch throw out bearing and pilot bearing. As well as a new shift cable. All for an 87, now I have read threads about using a 95 trans just use the 87 bellhousing and input shaft. Well the guy didn't listen and installed everything from the 95 trans. I was sitting at a light and next thing I know I press the pedal and I heard a loud popping sound. Then wouldn't go into first. So i shut the car off put it in gear the tried to crank, but csr wanted to move each time. What's the best thing to do to fix the issues.
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
RaysV6 is offline   Reply With Quote
Old 04-21-2015, 06:12 PM   #2
smurf stang's Avatar
Did you pop the cable?
You are gonna have to investigate some more.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 04-21-2015, 06:31 PM   #3
RaysV6's Avatar
I had the car towed to a shop and finally they somewhat looked at it. And said the plastic quadrant was broke. So i just placed an order for a steeda adjustable cable with dual hook quadrant. They said that it will fix all my issues.
Old 04-22-2015, 07:00 AM   #4
Varasios's Avatar
I've heard the maximum motorsports clutch cable kit and quadrant is the best and only aftermarket cable to go with
Using on my build in process. Hoping it operates as they say.
Varasios is offline   Reply With Quote
Old 04-22-2015, 07:06 AM   #5
RaysV6's Avatar
Quick fix for now. V I heard the same. BBK could t stack up against others. But for now I'm gunna use the steeda, and see what happens. I just want to drive her hahaha
Old 04-23-2015, 11:40 AM   #6
If you have a SN95 bell/input in there then you should drop the car off at the shop and tell them you're going to get a lawyer if they don't pull it back out and do what you told them to do.
As far as the cable, the steeda one is not as good as OEM/MM, not even close.
Old 04-25-2015, 09:44 PM   #7
RaysV6's Avatar
Well for now it's a quick fix to my issues. As far as the bell housing and I out shaft, it was the guy who I bought the car from. But since I have the new Steeda clutch cable with dual hook quadrant, and firewall adjust it seems to be shifting great. Just needs alot of work. Sometimes I wonder was this a good idea. Hahahaha
Old 05-06-2015, 06:36 PM   #8
RaysV6's Avatar
Well the thing with clutch cable, I'm having shifting problems it takes me some time to shift gears. I have to force the clutch pedal down, especially when it heats up. And with the cover of the shift fork missing, my longtubes are right there. Not sure what it is or causing it. But I need some input fellas
Old 05-06-2015, 06:46 PM   #9
Wrap the longtubes, get a dust cover from the JY, replace the Steeda cable with an OEM cable. And this is from a guy who just bought a Steeda Mustang lol.
Old 05-06-2015, 06:51 PM   #10
RaysV6's Avatar
Lol, yeah I had an oreillys cable on there and it was just coming through the firewall. Just getting irritated with it. I need to drive it and I want it to shift really good, with no issues
Old 05-07-2015, 07:19 AM   #11
Make sure the cable is away from the headers. Route it away.
Most aftermarket clutch cables are junk like it has been stated. Go to the MM site and check it out.
Old 05-07-2015, 02:50 PM   #12
RaysV6's Avatar
Ordering an mm kit hopefully tomorrow. Shop told me today, that he has dealt with mm before and ford oem cables are where it's at. So I'm buying another clutch cable tomorrow.
Old 05-07-2015, 03:26 PM   #13
lolz, told ya. go on the mm site and look at the aftermarket/oem compare pic. ugh, i need to see wtf quadrant and cable are in the car i just bought. i have a bad feeling its the steeda adjustable cable because no firewall adjuster and no self adjusting sound when i pull up...
Old 06-15-2015, 07:38 PM   #14
RaysV6's Avatar
Ok fellas remember when i first started this thread and mention a bad shifting from the clutch? Well i took the trans out by myself backyard style and found it was a destroyed throwout bearing. Im wondering if he installed it wrong when the guy installed it, the guy i bought the car from atleast
Old 06-16-2015, 05:38 AM   #15
Might have just cheaped out and put the same bearing back in? I've found too many times that ppl are idiots unfortunately.
Old 06-16-2015, 05:42 AM   #16
RaysV6's Avatar
Well the t/o bearing was brand new. Gunna call ford and see if they have a part number to the one they sell and see if it looks better
Old 06-16-2015, 06:10 AM   #17
He might have installed it wrong. Just look it up on ford partsnation or just google "tousley ford" and look it up on their ordering page. They're not Tousley anymore tho... its called something else but the google will find it.
auto trans limp mode issues...... rinfield2004 Pre-2005 V6 Mustang 8 10-11-2013 11:43 AM
just put auto trans in standard car having issues with going forward B Wilkey Pre-2005 V6 Mustang 9 03-26-2013 05:10 PM
66 mustang - trans issues Mac14 Classic Mustangs 7 09-27-2012 09:58 AM
Trans issues...... rinfield2004 Pre-2005 V6 Mustang 6 08-24-2012 07:35 AM
00 gt auto trans issues cue59 1996-2004 Mustang GT 9 02-17-2009 04:12 PM
06:16 PM
