Engine oil for turbo car - Mustang Evolution
Old 04-26-2015, 07:31 PM   #1
Adogg's Avatar
Hey guys quick question, what is the best oil to use on a turbochargered 5.0??
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
Don't hate....... appreciate
Old 04-26-2015, 10:54 PM   #2
Turbocharged engines are the only application where I believe that using a full synthetic oil is beneficial.
Old 04-27-2015, 08:49 AM   #3
Adogg's Avatar
Yes I think so also I'm thinking like 5w-30 maybe -20
Old 04-27-2015, 08:53 AM   #4
Rapinator126's Avatar
All depends on rpm also. You want a heavier weight oil for high rpm motors.
Old 04-27-2015, 09:14 AM   #5
smurf stang's Avatar
5w20 is a bit thin for these old pushrod motors.
Oil quality and life would mater more to me.
2016 VW GTI 2.0 Turbo
Old 04-27-2015, 09:51 AM   #6
Adogg's Avatar
So not going with 5w20 so what is everyone's recommendations?? It's not going to be really high rpms
Old 04-27-2015, 12:03 PM   #7
It depends on how the engine was built. An engine built for high boost levels will have larger tolerances to be able to withstand the extra heat buildup, so consequently, will need to use an oil with greater viscosity... Like 20w50. If the engine is stock, and running low boost, you should just stay with the recommended weight oil for that engine, which I believe is around 10w30 or 10w40, but just upgrade to a synthetic.
Old 04-27-2015, 01:38 PM   #8
Run 20w-50 in our Porsche, it does great...
Adventure till you drop
Old 04-27-2015, 01:44 PM   #9
Air-cooled and water-cooled engines are kind of an "apples and oranges" comparison but you get the picture.
Old 04-27-2015, 01:52 PM   #10
Air cooled dry sump and water cooled wet sump, would be the way to compare. But boost is boost same basic principle, heavier oil for high rpms, as stated. Which having a coyote it would most likely need a heavier oil, due to its high revving capabilities. But as stated all depends on the build, more questions need answers before oil comes up...
Old 04-27-2015, 03:48 PM   #11
Adogg's Avatar
I see what what you mean it's on a stock block with heads cam intake on low boost
Old 05-05-2015, 04:29 PM   #12
5w30 full syn.
Sent from my LG-D801 using Mustang Evolution mobile app
Can synthetic oil ruin my engine? Is Dino Oil better? collin 1979-1995 Mustang GT 17 08-09-2017 01:26 PM
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 03:27 PM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
My car is ford mustang 2001. I need to get the oil engine fixed. My oil level is on minimum.? iseabail 1996-2004 Mustang GT 5 03-14-2010 09:58 PM
11:15 PM
