5.0 Ranger Questions - Mustang Evolution
Old 05-03-2015, 09:24 PM   #1
Hey guys and gals, I have a 94 ranger with a swap from an 86 TBird. It is a good clean swap complete with a nice shifting AOD. I have a GT40 top end I am wanting to bolt on and just had some questions. My truck does have MAF and the orange top injectors. I do not know if these were on 86 birds but every number I have pulled says the engine is from an 86 bird. It is a very clean install and everything works. I am pretty sure it has a non roller cam but does have the roller block (if my research is correct) I would like to go with a complete engine from an explorer but do not want to change my harness out. Is there an ECM that will plug right up and do I just run the HO firing order on the dizzy? And will my current FI setup work? Thanks in advance.
Gauge is offline   Reply With Quote
Old 05-05-2015, 03:43 PM   #2
wbrockstar's Avatar
You'll have to use the computer and harness out of the salvage vehicle the engine is being pulled from.The first link below is for 302/351 swap into 83-97 Rangers.The second link is for a (96-97.5) 5.0 Explorer engine into a 98 and older Ranger or a (98-01) 5.0 Explorer engine into a 99-up Ranger.If a 98-01 Explorer engine is used in a 98 and older Ranger,you'll have to deal with the PATS system, which gets explained in the second link below.
http://www.therangerstation.com/tech...versions.shtml
http://www.therangerstation.com/tech...r_ranger.shtml
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Tell me what you think of this ranger sonic04edge Pictures and Videos 19 02-11-2005 10:00 PM
Been working on a highlights film for my ranger forum sonic04edge Pictures and Videos 1 02-04-2005 05:42 PM
04 ranger or 05 v6 stang? sonic04edge The Bar 20 12-26-2004 02:51 PM
2004 Ranger? FloMasta24 Pre-2005 V6 Mustang 28 12-21-2004 11:07 PM
whoo might be sellin ranger in late spring/early summer Bane- The Bar 5 11-28-2004 07:47 PM
06:24 AM
