Need help figuring out what type of suspension this is! - Mustang Evolution
Old 05-04-2015, 05:59 PM   #1
Hey what's up guys, when I bought my notchback it had this suspension and the dude told me it was an expensive suspension, does anyone have any idea what type it is? And what it is worth? Any help would be appreciated thanks
Sent from my SAMSUNG-SM-N915A using Mustang Evolution mobile app
ID:	181841   Click image for larger version
baynotch650 is offline   Reply With Quote
Old 05-05-2015, 02:58 PM   #2
wbrockstar's Avatar
Is it subframe connecters,torque arm,etc??I can't tell if its running down the center of the car or more towards the outside where subframe connecters run.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-05-2015, 03:26 PM   #3
It's running more on the outside not in the center..and it's on both sides
Old 05-05-2015, 07:09 PM   #4
wbrockstar's Avatar
It appears to be subframe connecters then.If you don't know what they're used for,they basically tie the front & rear unibody together so it will be similar in strength to a full frame.It keeps the body from twisting and flexing and it prevents the floorpan from cracking due to age or hard driving conditions such as drag racing,road racing,improves handling,etc.Some brands also include a T type addition that attaches to the bolts on the front seats to help strengthen that area.The link below shows an example of this type of subframe connecter.If this looks similar to what's installed under your car,you've definitely got subframe connecters. They range from $75+ and the weld on type are stronger.
"Super Subs" Subframe Connectors for 1979-2004 Mustang and Cobra | Shop Kenny Brown
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 05-05-2015, 07:21 PM   #5
Oooooh ok cool makes sense..thanks a lot bro, ever since I got this car I have been searching to see what is was..I never actually found that brand advanced suspension though even googling it, I would think there was something on this brand online but guess not..but thankyou for your help I really appreciate it
Old 05-05-2015, 07:21 PM   #6
wbrockstar's Avatar
There is also a brace called a Jacking Rail that gets installed closer to the outside of the car,compared to the subframe connecters.It gets used for jacking up the car which prevents damage to the unibody.It also helps strengthen the car.
Jacking Rails for 1979-1993 and 2005-2014 Mustang, Boss 302, and GT500 | Shop Kenny Brown
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 05-05-2015, 07:30 PM   #7
wbrockstar's Avatar
I also tried to look up that brand and nothing came up except for advanced racing suspension which was a strut/shock company.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 05-06-2015, 05:35 AM   #8
Subframe connectors are $400 for parts plus labor, never heard of that brand before. So no, not expensive. That pic of the rear looks like the control arms are stock... I hope you didn't pay for "premium" suspension.
need help figuring this out kgorham Pre-2005 V6 Mustang 2 04-16-2014 11:02 PM
I need some help figuring out how to do this thing on a car. Can someone help? bao General Mustang Discussion 2 07-20-2011 06:57 AM
Need help figuring out which wheel this is... Dark04ShadowV6 1996-2004 Mustang GT 16 09-23-2008 07:10 AM
need help figuring out timing bearbackcowboy Pre-2005 V6 Mustang 1 09-18-2008 09:31 AM
11:54 PM
