4.6 into 90 fox - Mustang Evolution
Old 05-07-2015, 10:21 PM   #1
jac142192's Avatar
4.6 into 90 fox
I have a 1990 notch roller and I have a 1996 Thunderbird no longer need the t bird so I am tossing around the idea of putting it in. Attempt or steer clear?
Sent from my DROID RAZR HD using Mustang Evolution mobile app
jac142192 is offline   Reply With Quote
Old 05-08-2015, 07:19 AM   #2
lots of modfox write ups. easiest if you have a whole donor car. electronics, harness, fuel, driveline etc... t bird will probably be ok for this.
Old 05-08-2015, 12:46 PM   #3
smurf stang's Avatar
Or you can carb it.
2016 VW GTI 2.0 Turbo
Old 05-08-2015, 04:45 PM   #4
jac142192's Avatar
Yeah I would probably just carb it and see how that goes.
Old 05-08-2015, 05:34 PM   #5
You can always do that too. Swap in the modular and then a normal carb conversion. Fuel rails and everything should bolt right up. You will need to find a T-45 or 3650 transmission though, or a Mustang automatic and a controller or MVB. Or a T-5 mated to a Quicktime housing...
Old 05-08-2015, 05:38 PM   #6
jac142192's Avatar
Interesting. Thanks for the info. I just need to figure out what transmissions will bolt 4.6.
Old 05-08-2015, 05:46 PM   #7
Any T-45, any 01-04 T3650 any T-56 with a modular bellhousing and a T-5 will also do it with the Quicktime scattershield. TKOs also bolt to that and have their own bells but TKOs shift like truck transmissions. Any 96-04 4R70W/4R75W will also bolt to them.
Easiest one in this sort of swap would be a 96-98 T-45 since they have the provision for a mechanical speedo which the Fox has. I'd get a rebuilt one from T45source.
Old 05-08-2015, 06:50 PM   #8
jac142192's Avatar
Well thank you very much. You've been very helpful.
Old 05-08-2015, 10:34 PM   #9
jac142192's Avatar
Wouldnt I be able to use the 4r70w that's in the Thunderbird? I'm not to worried about the speedo because there's nothing there anyways. The car is basically gutted.
Old 05-15-2015, 06:10 AM   #10
wbrockstar's Avatar
You know what,conversations are so popular these days,especially with the quantity of Foxbodys dwindling to get parts from.If someone had some money set aside and wanted to start a new business venture,conversions would be a good money making thing.You could buy wrecked modular powered Mustangs,take everything needed for a 100% complete conversion out of the Mustang and sell it as a complete diy package. That would help the guy ,that's timid about the swap or not knowledgeable enough to know what parts in total are needed ,get a complete swap done with 0 hassles.Unfortunately I don't have the funds to start this venture.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-15-2015, 06:21 AM   #11
Tailshaft is longer. Mustang has a special short tailshaft.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-16-2015, 02:27 AM   #12
mike s's Avatar
There is a shop in South Carolina doing this very thing. Actually talked to them the other day about a terminator swap for mine
mike s is offline   Reply With Quote
Old 05-18-2015, 09:30 AM   #13
What did they say about the terminator swap iv wanted to do that for a while now.
goosetoff is offline   Reply With Quote
Old 05-18-2015, 10:41 AM   #14
If you are going to do a Terminator swap, find a wrecked Terminator. That way you have a complete straight swap and all the parts on hand, no surprises or having to hunt down random parts. Otherwise, just 4V swap whatever you have with a built one or just build the 2V. Built 2V with ported heads/stock intake/blower cams will do 600+ with a S trim easy. No need for 4V and the added weight/valvetrain. Also the 2V sounds NASTY with cams almost like an old school pushrod where the 4V never will sound as good.
Old 05-18-2015, 07:16 PM   #15
mike s's Avatar
Going to be looking at 10-15 for the termi swap...really depends on how extensive you want to go. I was considering swapping dash, seats, the whole nine yards
Old 05-18-2015, 08:56 PM   #16
$15k to swap in a Termi? Lol that is ****ing ridiculous. I mean I understand what the labor costs and getting the parts but at that price just sell your car and buy a Terminator for $20-$24k. Or a Coyote.
Old 05-19-2015, 07:29 AM   #17
mike s's Avatar
If you have a really good body and want to stay fox it would be worth it. A clean termi is rising in cost every year and all of the parts are really expensive. I really thought for all of the parts and labor it wasn't that bad. 12-15k turn key seems realistic
Old 05-19-2015, 07:34 AM   #18
mike s's Avatar
4.6 into 90 fox
if you figure a t56 alone is 3k new without anything termi motor is 6-8. That turn key price really isn't that bad when you add it all up. Now obviously there are other ways and cheaper ways to get that power level. But I would love to have my convertible termi swapped now I probably won't ever do it but it would be badass
Old 05-20-2015, 10:15 PM   #19
olerodder's Avatar
Region: Oregon
This is what you could do and it could be the ultimate sleeper.
Name:	Fox body with 4.6.jpg
ID:	183045   Click image for larger version
Name:	Fox body with 4.6 2.jpg
Name:	fox body with 4.6 3.jpg
Old 05-21-2015, 06:42 AM   #20
mike s's Avatar
That looks awesome very clean swap
Mk. VIII Engine into a Fox? LaseRedXD SVT Mustang 5 10-25-2012 09:21 AM
3.7liter into a fox body swap Newline 1979-1995 Mustang GT 5 01-22-2012 09:21 AM
Can I install a 1973 351 Windsor and fmx transmission into a fox body mustang? yakov Classic Mustangs 2 12-20-2011 05:20 AM
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Fox 8.8 into a sn95 Roadhawg Pre-2005 V6 Mustang 12 11-21-2005 03:05 PM
04:33 AM
