Baer brake rear 5 lug swap? - Mustang Evolution
Old 05-17-2015, 12:16 PM   #1
Jinash's Avatar
So just finished a new Baer track kit swap on my 90 GT that I found on Craigslist. Getting a scraping sound from rear brakes. Visually I can't see a problem. Also using ranger axles from my previous 5 lug swap. Any body have experience with this swap? Thanks -J
Jinash is offline   Reply With Quote
Old 05-18-2015, 05:45 PM   #2
ALMOST STOCK's Avatar
Did you follow the Baer spec sheet for the adjustments of the rears between the caliper and the anchor plate ( minimum 0.030 and maximum 0.090)?
Mustang Monthly Jan 2015- Feature
5.0 Mustang & Super Fords July 2005
ALMOST STOCK is offline   Reply With Quote
Old 05-18-2015, 10:00 PM   #3
Jinash's Avatar
No I didn't, ( I didn't get any info with the kit) I've been trying to find it on line but no luck. So what's the best way to go about this? Put a washer between backing plate and caliper?
Thank you for info
Old 05-19-2015, 05:54 AM   #4
This is the instruction sheet for the rear I got from Baer when I swapped from 4 lug to 5 lug.
ID:	182927   Click image for larger version
Old 05-19-2015, 11:02 AM   #5
smurf stang's Avatar
Nice to see you again Paul.
And Almost Stock pretty much has every diagram and picture known to man that has to do with a fox body.
2016 VW GTI 2.0 Turbo
Old 05-19-2015, 12:54 PM   #6
Jinash's Avatar
I'm going to check it out after work, thanks for posting this info. There definitely wasn't shims with the kit I bought, also the hub rings were missing too but I ordered them from Baer
Old 05-21-2015, 09:59 AM   #7
IIRC (it was 15 yrs ago that I did mine) Baer didn't furnish any shims with the fit.
Old 05-21-2015, 10:02 AM   #8
Rick I gave up retirement and went back to work so it's not often I get the time to post on the Mustang sites any more.
I've decided to make this Memorial Day weekend a 5 day weekend.
You know what they say about all work and no play.
Old 05-21-2015, 04:43 PM   #9
Jinash's Avatar
Good info! Thank you, what did you use for to shim? Flat washers?
Old 05-21-2015, 08:22 PM   #10
I was able to adjust mine within the tolerances that Baer said without any shims.
Old 05-23-2015, 12:43 PM   #11
Jinash's Avatar
Ok, finally got around to checking this out. Here's what I found- Click image for larger version
Name:	ImageUploadedByMustang Evolution1432406533.826197.jpg
Rotor is grinding on backside of caliber bracket. Should I take a Dremel and take out some material where it is rubbing?
Old 05-24-2015, 07:54 AM   #12
I would try shimming it first before I thought about removing any material.
I would email Baer and ask them how to solve the problem.
Baer Brakes - Big Brake Kits
Old 05-26-2015, 01:49 PM   #13
True.
Old 05-31-2015, 09:45 PM   #14
Jinash's Avatar
So I emailed Baer, waiting to hear back. I took some measurements and compared them to that last instruction sheet that was put up. Click image for larger version
Name:	ImageUploadedByMustang Evolution1433130108.685274.jpg
It appears my axle is about 1/4-3/8" short of the recommended 2&1/2"
Should I try to shim the caliper bracket off the axle flange that much or look into buying some new axles as the ones I have are from a junkyard 5 lug swap I did back in 02?
Old 05-31-2015, 10:20 PM   #15
Jinash's Avatar
Oops, just re-read my last post, shimming intermediate bracket off of axle flange would have same effect as shimming caliper bracket off of intermediate bracket?.?.? It's been a long week... I'm gonna wait to hear back from Baer before I proceed any further
Old 06-06-2015, 03:06 PM   #16
Jinash's Avatar
Baer got back to me and suggested clearancing the back of the caliper bracket where it attaches to axle flange plate. So I took the grinder to it and took off a bit of material. Bolted it back up and took it for a drive and all is well. Thank you everybody for your replies and info
Old 06-08-2015, 02:02 PM   #17
Glad it all worked out.
Front rotors for baer brake kit jjenks 1979-1995 Mustang GT 0 11-10-2014 12:31 PM
4 Lug to 5 Lug Help... SC_STEEDA Classic Mustangs 7 06-18-2009 07:45 PM
12:39 AM
