Dilemma.. - Mustang Evolution
Old 05-19-2015, 09:26 PM   #1
jriccard's Avatar
Dilemma..
So I'm thinking I have a short. My dome light is stuck on and I think that's why the previous owners battery was dead. I unhooked battery and rehooked It and light stayed on. Light dimmer switch does nothing. Also just purchased a brand new battery but car hesitates to start. I know the battery has a charge but the terminals are messed up. Do you think it's the terminals or the alternator?
Thanks!
'88 GT
jriccard is offline   Reply With Quote
Old 05-20-2015, 01:43 AM   #2
Foxbody91's Avatar
Just take it somewhere and have them test ur battery and alternator it's free. Then go from there, if one or both are bad change them out and see if the light works properly
Foxbody91 is offline   Reply With Quote
Old 05-20-2015, 02:01 AM   #3
Foxbody91's Avatar
Sounds like a battery issue..check your terminals make sure they are tight, even pull them off and scrape inside loop of the terminals to get a smoother connection. Check for corrosion. After that start looking elsewhere, ignition switch, starter, maybe even spark plugs but neither of those will cause your light to stay on which is y I'm leaning towards your battery
Old 05-20-2015, 02:10 AM   #4
jriccard's Avatar
Battery is brand new. Just replaced terminals as well. Car still won't start and battery light is still on. Has to be alternator.
'88 GT
Old 05-20-2015, 02:11 AM   #5
jriccard's Avatar
I can't even get it anywhere to be tested
'88 GT
Old 05-20-2015, 09:55 AM   #6
Shifty 5.0's Avatar
If the battery light is on replace the alternator and now is the time to do the 3 g swap that is a must on foxbodys
Shifty 5.0 is offline   Reply With Quote
Old 05-20-2015, 10:02 AM   #7
jriccard's Avatar
Can you explain what a 3 g swap is?
'88 GT
Old 05-20-2015, 10:09 AM   #8
Strange Mud's Avatar
I would check out the door switchs for the dome light issue. For the hesitation are you sur you have good connections at battery?
Old 05-20-2015, 10:20 AM   #9
jriccard's Avatar
Yes. Terms were just replaced
'88 GT
Old 05-20-2015, 10:45 AM   #10
jriccard's Avatar
It was the alternator. Just had it checked
'88 GT
Old 05-20-2015, 02:06 PM   #11
smurf stang's Avatar
I hope you installed a 3G.
2016 VW GTI 2.0 Turbo
Old 05-23-2015, 10:30 AM   #12
Liebert91stang's Avatar
Stock altonator suck.they barley have enough to to run lights and radio.i would go 3G altonator.its an easy conversion.
Liebert91stang is offline   Reply With Quote
A little Dilemma... AlexJ Pre-2005 V6 Mustang 3 03-17-2010 02:56 PM
Project Fox Storage Dilemma - Help Please PureVenom General Car Discussion 4 03-27-2008 06:06 AM
Dilemma! Thomas91169 The Bar 23 09-27-2007 04:24 PM
Dilemma: Laptop and OS wiarumas The Bar 13 01-11-2007 12:59 AM
I have a HUGE dilemma Zim The Bar 31 07-27-2005 04:46 PM
08:22 PM
