1/4 mile predictions???? - Mustang Evolution
Old 05-21-2015, 07:32 PM   #1
Christian_S's Avatar
Name:	ImageUploadedByMustang Evolution1432258243.396386.jpg
Hey what's up guys if you look above I have a picture of my best time to date. Disappointing I know. Numbers were faded so I had to rewrite them. I'm getting ready to install a dry nitrous kit on my car. I'm thinking on running between 100-125 hp shot And I wanted to know what you guys think I'll do on the 1/4
My current mods are, trick flow street burner intake, bbk throttle body, cai, non ported Gt40p heads, b303 cam, stock bottom end, 3.73 gears, x pipe and 275/50/15 nitto nt555r's with skinnies on the front.
I'd like to see if it's really worth it. I have a target number what do you guys think I'll do??
Budget 92 GT
Christian_S is offline   Reply With Quote
Old 05-22-2015, 09:50 AM   #2
smurf stang's Avatar
If you don't have good tires get ready to spin like a mofo.
Plus you got to learn the car.....shift points, launch rpm, how to slip that clutch ever so slightly, tire psi (DR).
2016 VW GTI 2.0 Turbo
Old 05-22-2015, 09:56 AM   #3
Thanks for the input. I drive the car A lot so drag radials are good for me. What tires would you recommend? MT Street ET's?
Budget 92 GT
Old 05-22-2015, 09:58 AM   #4
What if I just drop them to 18psi and get them really hot?
Budget 92 GT
Old 05-22-2015, 01:59 PM   #5
Getting street tires really hot just makes the greasy and slick believe it or not. Also dropping them really low on pressure is not got also. You can drop them a little to like 25 but other than that you are just hurting yourself.
On street tires a good 60' is around 1.8xx. Drag radials are needed to harness the power after that.
Also what do you shift at? Have you played with shift points as with your setup doesn't really make much power past low 5,000 rpm.
Old 05-25-2015, 11:12 PM   #6
That is a really slow time for the mods you have. I am assuming you have exhaust and all the other stuff? I see no mention of a tune, if you don't have one yet, that is your very next modification to the car.
Suspension/tune/driver mod should have that car in the 12s. I'm not kidding.
Old 05-27-2015, 07:02 PM   #7
Thanks for the comment man I appreciate it. Do I need a aftermarket each to be able to tune the car?
Budget 92 GT
---------- Post added at 08:02 PM ---------- Previous post was at 08:01 PM ----------
*ECU
Budget 92 GT
Old 05-27-2015, 09:41 PM   #8
No you need to take the car to a dyno tuner and get an actual chip for the ECU and a tune will be burnt to it. The guy near me uses Diablosport chips for 95-down computers. The bama one you have was a complete and total waste of your money unfortunately.
Old 05-30-2015, 09:27 AM   #9
Thanks for the advice man! I'm getting a sct a guy near me tunes with those
Budget 92 GT
Old 05-30-2015, 01:29 PM   #10
Not a handheld, those don't work on obd1 cars.
Sent from my LG-D801 using Mustang Evolution mobile app
1/8 mile and 1/4 mile times Jvibe92 2011-2014 Mustang GT 4 05-04-2015 09:12 PM
SEC Championship predictions: MarkuzLS1 The Bar 15 12-03-2006 04:56 PM
So let's hear the predictions: MarkuzLS1 The Bar 19 11-20-2006 11:01 AM
Getting Dyno Tuned this weekend. Number predictions? Monkey The Bar 2 10-10-2005 09:39 PM
NBA Predictions Falcon The Bar 8 05-15-2004 01:29 AM
10:26 PM
