1995 pulley squeaking - Mustang Evolution
Old 05-29-2015, 03:55 PM   #1
nrwas326's Avatar
Hey guys whenever I start my car the pulleys always squeak and then it stops right after. What do you recommend? And I just put a new serpatiene belt on it and no pulleys are loose
nrwas326 is offline   Reply With Quote
Old 05-29-2015, 08:23 PM   #2
wbrockstar's Avatar
I would check the tensioner pulley to make sure its working properly to keep the belt tight.It has a dot or arrow on the face of it which needs to fall within the range that's marked on the front.The spring inside of the tensioner can weaken & this will cause a loose belt.Make sure the pulley itself doesn't squeak,wobble or drag when free spinning it.A stretched belt will also cause noise.All of the pullies should freespin except for the crank.The smog & water pump will have slight resistance,compared to the ac,alternator & tensioner.I've seen several smog pumps seize or bind up after years of use.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 05-29-2015, 08:31 PM   #3
oxford5pointoh's Avatar
Idler bearing is probably shot. I'd replace the idler. Cheap and easy.
IG @Oxford5pointoh
Old 05-29-2015, 08:46 PM   #4
Replace idler and tensioner pullies. Buy them on rockauto, don't pay local parts store prices.
Old 05-29-2015, 11:31 PM   #5
nrwas326's Avatar
Thanks everyone for the feedback!
Old 06-01-2015, 07:48 AM   #6
smurf stang's Avatar
Make sure you also report back when you fix the problem and close the case to the "Squeaky belt and pulley dilemma".
2016 VW GTI 2.0 Turbo
Old 06-11-2015, 03:02 AM   #7
GT1995's Avatar
bearring on my smog pump went out and created noise (because I didnt install a AC delete pully) When i did a AC delete and it caused too much tension on the other bearings
NO MORE SQUEAK
GT40P Heads, GT40 Intake Manifold, 70mm TB, Cold Air, 24lb injectors, SCT Tuned, need more speeeeed
GT1995 is offline   Reply With Quote
1995 Mustang Cobra :: 1995 Ford Mustang Cobra jwhayne0001 Member Garages 0 08-20-2011 11:22 PM
1995 Mustang GT :: 1995 Ford Mustang Ripastanky Member Garages 0 06-15-2011 12:01 PM
Polished water pump pulley and alt pulley for 01-04 4.6 2v Everett Mustang Parts for Sale and Wanted 1 03-17-2011 02:52 PM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
can't stop doors from squeaking stangracer Mustang Audio & Video 11 11-11-2003 11:08 AM
02:36 PM
