Wet spark plug - Mustang Evolution
Old 05-30-2015, 02:57 PM   #1
Christian_S's Avatar
Wet spark plug
Name:	ImageUploadedByMustang Evolution1433019339.006334.jpg
I just pulled this spark plug out all of the other cylinders were completely dry and this one is wet. what do you guys think this is?
Budget 92 GT
Christian_S is offline   Reply With Quote
Old 05-30-2015, 03:06 PM   #2
oxford5pointoh's Avatar
Looks like you might have a bad ring on that piston. Maybe do a compression test.
IG @Oxford5pointoh
Old 05-30-2015, 10:34 PM   #3
Shifty 5.0's Avatar
Check this out.Click image for larger version
Name:	ImageUploadedByMustang Evolution1433046885.994977.jpg
Shifty 5.0 is offline   Reply With Quote
Old 06-01-2015, 07:53 AM   #4
smurf stang's Avatar
Do a leak down test which should let you know if you got some compression escaping.
2016 VW GTI 2.0 Turbo
Old 06-01-2015, 09:26 AM   #5
rocknbronco's Avatar
Bad rings would be my first guess.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 06-01-2015, 08:52 PM   #6
I'm with everyone else... probably bad rings, one thing the 5.0 can be common for is bad rings. I rebuilt my engine last year due to heavy oil consumption from poor rings. I did a dry compression test, then a wet compression test, which raised the compression due to poor ring seats, and then did a leak down test, which all cylinders had between 20-80% leakage lost all through the crankcase.
Sent from my VK810 4G using Mustang Evolution mobile app
94yellowsn95 is offline   Reply With Quote
Old 06-03-2015, 08:25 PM   #7
Would it be bad if Instead of doing a rebuild I just swapped rings?
Budget 92 GT
Old 06-03-2015, 08:28 PM   #8
If you have the engine torn down to replace rings, it wouldn't be much more for at least replacing at least the crank and rod bearings. You will also want to have the cylinder walls re-honed, or the new rings will never reseat properly
Sent from my XT1254 using Mustang Evolution mobile app
Old 06-03-2015, 08:30 PM   #9
That's what I'm planning on thank you
Budget 92 GT
Old 06-03-2015, 08:32 PM   #10
No problem. Just FYI, my background, I am a master ASE certified technician... If you have any technical questions, feel free to message me
Old 06-04-2015, 10:24 AM   #11
Try to find a lower mileage explorer pullout. Swap your mustang cam in with new valvesprings and your front accessories and drop it right in and gain 50rwhp in the process.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-05-2015, 08:07 PM   #12
You guys are awesome thank you for the info!
Budget 92 GT
Old 06-06-2015, 08:29 AM   #13
Would the Pistons that came in the explorers handle a 125shot? They didn't come forged right?
Budget 92 GT
Old 06-06-2015, 04:05 PM   #14
Nope but they'll handle as much as the forged ones. Forged ones are just more resistant to detonation... Which you should not have if you have a good tune.
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Spark Plug Wires Laser02 Pre-2005 V6 Mustang 32 11-08-2004 08:30 AM
Spark Plug Wires Shahrum Pre-2005 V6 Mustang 10 02-05-2004 10:09 AM
Spark plug change Rellik The Bar 7 08-20-2003 06:04 PM
09:02 AM
