94 GT turbo help - Mustang Evolution
Old 05-31-2015, 05:50 PM   #1
94 GT turbo help
I have a 94 gt with a turbo. Don't know to much about turbos but when I boost it I get some oil out of one of the breathers. Was told its blow by that it's prolly a piston ring. I told another guy I was getting blow by and he instantly said I needed to rebuild my motor which I don't think I need to. What do u guys think.
Sent from my N9520 using Mustang Evolution mobile app
turbostang_94 is offline   Reply With Quote
Old 05-31-2015, 08:50 PM   #2
Shifty 5.0's Avatar
Are you running a catch can of any sort?
Shifty 5.0 is offline   Reply With Quote
Old 05-31-2015, 10:00 PM   #3
Delete your PCV system completely if its not already. You are pressurizing the crank case which is very bad. This means that whoever did the install of the turbocharger half assed that part of it. If you run a PCV system with a blower you need to install aftermarket specially designed check valves in the system because the OEM PCV will leak badly under any sort of boost. Just deleting it is much easier.
This begs the question, what else did they not do correctly on the car? Is this a name brand turbo kit btw or a DIY? You have any idea what sort of tune is on the car, what fuel system or anything like that?
Old 05-31-2015, 11:41 PM   #4
I planned on a catch can. It's a complete on3 turbo. I got it from a guy thinking I could fix it but I'm more familiar with superchargers. There wasn't even any breathers on the car when I got it.
Old 05-31-2015, 11:43 PM   #5
If it is the piston ring what kind of damage would I do to the car if I keep driving it
Old 06-01-2015, 07:36 AM   #6
smurf stang's Avatar
Do what Scotty said first.
Then if you can do a compression and a leak down test which will give ya some indication of the general health.
2016 VW GTI 2.0 Turbo
Old 06-01-2015, 09:29 AM   #7
rocknbronco's Avatar
Half way doing a car mod is silly and sticking somone with a project that you screwed is even worse.
Follow Scottys advice.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 06-01-2015, 10:16 AM   #8
I noticed a hose underneath the car that looks like nothing but steam or smoke comes out I'm assuming it's the crank case. If I have a bad piston ring is taking out the pvc system gonna help
---------- Post added at 04:16 PM ---------- Previous post was at 04:15 PM ----------
And I'm not totally sure how to delete the pvc system. Sorry guys I can work on cars but don't know alot
Old 06-01-2015, 11:01 AM   #9
By deleting the pcv system is that taking the pcv valve or just capping it
Old 06-01-2015, 11:52 AM   #10
I talked to the previous owner he said that he open vented it cut the end off so air could only get out not go in
Old 06-01-2015, 11:56 AM   #11
Which is that hose I was talking about earlier that I seen under the car that is pushing out smoke
Old 06-01-2015, 01:53 PM   #12
Maybe a pictures to see where that hose is coming from.
Old 06-01-2015, 02:27 PM   #13
Need pics.
Old 06-01-2015, 03:28 PM   #14
Pcv
Old 06-11-2015, 03:07 AM   #15
GT1995's Avatar
Smoke from that hose is NO BUENO MAN
GT40P Heads, GT40 Intake Manifold, 70mm TB, Cold Air, 24lb injectors, SCT Tuned, need more speeeeed
GT1995 is offline   Reply With Quote
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 03:27 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
04 v6 turbo....help Big Nick Pre-2005 V6 Mustang 13 07-26-2008 12:37 PM
help turbo 3.8 project garybird440 Pre-2005 V6 Mustang 5 03-21-2008 12:33 AM
need help with Turbo Tax 2004 jimmy_beaner The Bar 2 10-09-2005 07:10 AM
05:26 PM
