Guess my HP cause im 2 broke for DYNO 0)': - Mustang Evolution
Old 06-11-2015, 02:58 AM   #1
GT1995's Avatar
Talking Guess my HP cause im 2 broke for DYNO 0)':
someone wanna guess at my hp for me cause Im 2 broke after my mods to have it dynoed and i want to be able to have a number for when people ask lol
95 GT- 100k Miles
EGR Delete
SCT Chip Tuned
GT40 Upper/Lower
70mm TB
BBK CAI
24lb Injectors @49psi
24lb 75mm MAF
looking for RWHP and at the crank
GT40P Heads, GT40 Intake Manifold, 70mm TB, Cold Air, 24lb injectors, SCT Tuned, need more speeeeed
GT1995 is offline   Reply With Quote
Old 06-11-2015, 03:19 AM   #2
bucko's Avatar
Sixty twelve.
I'm also too broke to make realistic HP guesses without the use of a dyno!
Old 06-11-2015, 05:12 AM   #3
smurf stang's Avatar
24 lb injectors and you have the fuel pressure turned up to 49?
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 06-11-2015, 05:27 AM   #4
doyouevenforum
Guest
Posts: n/a
650 to the wheels and about 165 at the crank
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-11-2015, 08:51 AM   #5
GT1995's Avatar
Smurff
sorry! 39psi!! That's a good pressure right?
Old 06-11-2015, 10:21 AM   #6
Varasios's Avatar
My guess,
280-310 rwhp
365-380 to the crank
Just guessing for fun 😎
Varasios is offline   Reply With Quote
Old 06-11-2015, 10:42 AM   #7
A million
Old 06-11-2015, 01:05 PM   #8
Jbone007's Avatar
Well stock they were underrated at 215hp/285lbft, at the crank, for insurance reasons, were closer to 225hp/305lbft at the crank. So with the mods you have you should be close to the 300hp mark at the crank,
Jbone007 is offline   Reply With Quote
Old 06-11-2015, 01:14 PM   #9
Originally Posted by Varasios View Post
My guess,
280-310 rwhp
You're smoking crack. My HCI Cobra made 301 to the wheels. Not a snowball's chance in hell he is anywhere close.
Nope, they made about 185-190rwhp bone stock. The E7 heads are that bad. Nothing he has done except the GT40 intake is going to add any power. Maybe the chip depending on how decent he canned tune is.
My guess is somewhere from 205-215 to the wheels.
Old 06-11-2015, 01:56 PM   #10
Jbone007's Avatar
Well we are all guessing some a little more than others!
Old 06-11-2015, 03:29 PM   #11
Varasios's Avatar
Thought I read gt40 heads aswell
Yes the crack was flowing
We call it marijuana in Canada tho 😎
Old 06-11-2015, 04:10 PM   #12
Strange Mud's Avatar
a decent amount....not as much.
Old 06-11-2015, 07:55 PM   #13
GT1995's Avatar
Lol I'm pretty sure injecotrs, cold air and throttle body had some power. What should I do next? I was thinking headers but what do you guys recommend? Cheap power!
Old 06-11-2015, 08:18 PM   #14
Why would injectors up your power? Heads don't flow enough to warrant bigger tb. 60mm stocker flows more air than they can use. Stock intake tube is already a CAI. Nothing you did except the gt40 intake is adding power to your setup. Maybe the chip. Maybe.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-12-2015, 05:59 PM   #15
216 to the wheels.
Get some used long tube headers and a off road h pipe.
Bump the timing.
Save some cash and keep looking at craigslist for deals.
Old 06-12-2015, 06:03 PM   #16
oxford5pointoh's Avatar
Who cares what the numbers are? Just take it to the track. Forget the water cooler talk.
IG @Oxford5pointoh
Old 06-12-2015, 06:22 PM   #17
If he has stock gears he'll run in the high 14s/low 15s. Stock gears are terribad.
Old 06-12-2015, 06:24 PM   #18
My point exactly. So why does it matter what his guesstimated HP and torque is. Lol. Still slow.
IG @Oxford5pointoh
Old 06-12-2015, 06:33 PM   #19
why don't you just tell people that ask that you don't know because you never got it dyno'd? perfectly reasonable response i think.
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Guess my dyno numbers :) Speed_Mister 1996-2004 Mustang GT 42 04-29-2014 08:13 PM
Any one wanna guess how much hp/tourque im going to dyno The420fox 1979-1995 Mustang GT 17 02-19-2013 10:25 PM
Guess which dyno graph is the V6, Blue or Red RGR Pre-2005 V6 Mustang 32 02-16-2005 02:38 PM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
07:34 PM
