95 loss of power - Mustang Evolution
Old 06-22-2015, 02:09 PM   #1
GT1995's Avatar
95 loss of power
So I blew a head gasket and I decided to go with gt40p heads to complete a gt40 swap on my 95 5.0
Idk what's wrong, it has a bad loss of power, rpms bounce at 4k some times. Haven't tried to fix anything yet so lmk what you guys think.
This car is a pain in my ***
GT40P Heads, GT40 Intake Manifold, 70mm TB, Cold Air, 24lb injectors, SCT Tuned, need more speeeeed
GT1995 is offline   Reply With Quote
Old 06-22-2015, 02:36 PM   #2
It could be so many things... You might not have a sensor hooked up right, you might have the distributor off, you might have installed the cam a tooth off you could have a vac leak somewhere you might have the firing order mixed up on the wires...
Going to have to go back over it completely and see what might be wrong.
edit: still stock cam right? If not then that might be your problem right there.
You did swap out the valvesprings on the P heads correct?
Old 06-22-2015, 03:37 PM   #3
GT1995's Avatar
i just went to pickn pull and took the complete head setup from a 97+ 5.0 explorer and put it on my block, all I used from my mustang was the pushrods
Old 06-22-2015, 04:24 PM   #4
Varasios's Avatar
Pushrod length has to be checked when changing the heads
Hopefully this is not your issue
Varasios is offline   Reply With Quote
Old 06-23-2015, 01:52 AM   #5
GT1995's Avatar
Forgot to plug in a spark plug lol,
Also when I full throttle it the rpms rise and sometimes I don't accelerate as much. I Just did a clutch job, any ideas? Maybe my gears are shot in my rear end or maybe tranny issues?
Old 06-23-2015, 06:09 AM   #6
Its always something stupid lol. If the motor is behaving the same all the time when you push the clutch and sometimes the car does not take off like it should... yeah you could have a glazed flywheel.
Did you install a new flywheel too when you did the clutch?
Old 06-23-2015, 12:51 PM   #7
GT1995's Avatar
Yea I replaced the flywheel! ):
Old 06-24-2015, 11:15 AM   #8
smurf stang's Avatar
Clucth is probably slipping some. So you installed a new clutch and flywheel....what about the cable, quadrant & adjuster?
Also the valve springs on the GT40 are notoriously weak and very light on pressure so expect to get valve float. http://www.fiveohinfo.com/performance/gt40-gt40p.html
I would also recommend measuring the pushrods like stated.
Check your timing and make sure it is good.
What spark plugs are you using?
2016 VW GTI 2.0 Turbo
Old 06-28-2015, 09:45 PM   #9
wbrockstar's Avatar
I would run a koeo koer test to verify whether any codes are present.The cel doesn't have to be lit in order for codes to be present.You don't need a scanner either,follow the steps in the link below.If any codes are present,it will help you diagnose the cause as possibly sensor,EEC-IV,wiring,etc but if no codes are present that will most likely indicate the cause as a mechanical one instead.
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure
---------- Post added at 09:45 PM ---------- Previous post was at 09:44 PM ----------
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Loss power and overheat, jerking, please help!!! kevpar07 Pre-2005 V6 Mustang 4 09-08-2007 11:25 PM
93 POWER LOSS jcori3 1979-1995 Mustang GT 17 09-19-2006 07:41 AM
oil change. alignment. loss of power Dark02Pony Pre-2005 V6 Mustang 19 10-21-2005 11:39 PM
Temporary Power Loss, Idiot Light BlueDonkey Pre-2005 V6 Mustang 6 11-05-2003 12:37 AM
power loss? 6erstang Pre-2005 V6 Mustang 7 09-03-2003 10:39 AM
10:16 PM
