Help! Oil pump rod retainer fell in engine... - Mustang Evolution
Old 06-22-2015, 02:02 PM   #1
Haav2's Avatar
Last Saturday me and a buddy of mine were doing an intake gasket on my 89 mustang 5.0.
I took off the intake upper and lower to clean up to install new gaskets.
My buddy pulled the distributor up to get it out and the rod was stuck in the dizzy. He pulled the whole rod with dizzy out of the engine and the oil pump retainer fell into the motor.
My question is, can I drain oil and the retainer will just come out? Or must I take the engine apart in order to get it out?
I've been told by some that the retainer is a soft metal and won't damage anything if I leave it in there. My next plan is to put a magnet on the outside of my oil pan so the retainer stays put until I can take the engine out again because it's a p.i.t.a. To get off when the engine is installed.
Any one who has had this happen please give me some advice as I am not sure what to do in this situation.
Thanks.
89 gt
5.0 roller bored .20 over
Sealed power Pistons
Vortec v3 11psi
Gt40 heads
Bbk 5001 intake
3.73 gears
Custom exhaust system
Haav2 is offline   Reply With Quote
Old 06-22-2015, 06:36 PM   #2
If you take the timing cover off, you can access the front of the oil pan, and you may be able to retrieve the retainer with a magnet or some other method.
If you can't get it out, it won't hurt anything. And someday it might come out during an oil change!
Old 06-22-2015, 06:38 PM   #3
Shifty 5.0's Avatar
That's happened to me so many times! Just go to the store an by one of the flexible claw tools and you can get in to like any space and get it
Shifty 5.0 is offline   Reply With Quote
Old 06-22-2015, 06:44 PM   #4
I suppose that if he gets a flexible retrieval tool with a small enough magnet on it, he may be able to "fish" it out through the distributor hole.
Old 06-22-2015, 07:53 PM   #5
Shifty 5.0's Avatar
Name:	ImageUploadedByMustang Evolution1435024379.495793.jpg
ID:	185574 This is what you need!
Old 06-22-2015, 07:56 PM   #6
Haav2's Avatar
Nyce!! That looks like it'll work. gonna get one of these tomorow and see how it all works out.
Old 06-24-2015, 10:23 AM   #7
smurf stang's Avatar
Also kick your friend in the balls.
2016 VW GTI 2.0 Turbo
Old 06-24-2015, 03:24 PM   #8
Haav2's Avatar
Lmao!! Will do.
Poly, Rod, or Poly/Rod panhard bar? Mustang Coyote 2011-2014 Mustang GT 2 12-19-2014 11:03 AM
Help! Ive been searching for a boot retainer Mustang lulu 2011-2014 V6 Mustang 4 07-03-2013 09:04 PM
2010 HD V-Rod Muscle :: 2010 Harley Davidson V-Rod Muscle Jetag93 Member Garages 0 08-12-2012 05:47 PM
11:22 PM
