Clutch - Mustang Evolution
Old 06-24-2015, 10:21 AM   #1
209stang's Avatar
Clutch
Does anyone know why my car doesn't want to or is a hassle to go into gears?
209stang is offline   Reply With Quote
Old 06-24-2015, 10:24 AM   #2
smurf stang's Avatar
New clutch? Old clutch?
What kind of cable?
What kind of adjuster?
Is it smooth when the car is off?
We need a ton more info here............
2016 VW GTI 2.0 Turbo
Old 06-24-2015, 10:36 AM   #3
209stang's Avatar
It's an old clutch from as far as I know of. I believe stock I haven't switched anything out yet. I'm not sure. Yeah it's smooth when the car is off.
Old 06-24-2015, 11:47 AM   #4
Foxbody91's Avatar
Is there a burning smell? Which gears are hard to shift? 1st? Reverse? It could be a number of things associated with your clutch so explain what makes u think ur clutch is going bad
Foxbody91 is offline   Reply With Quote
Old 06-24-2015, 01:13 PM   #5
209stang's Avatar
1st and 2nd are the most difficult. I kind of have to force it there and reverse at times.
Old 06-24-2015, 01:29 PM   #6
Foxbody91's Avatar
Any noises?
Old 06-24-2015, 01:45 PM   #7
209stang's Avatar
No no noise. I have to push the clutch to floor to start as well.
Old 06-24-2015, 01:53 PM   #8
Foxbody91's Avatar
Pushing the clutch to the floor to start is normal. Is ur clutch spongey?
Old 06-24-2015, 02:07 PM   #9
209stang's Avatar
What do you mean by spongy
Old 06-24-2015, 02:12 PM   #10
Foxbody91's Avatar
Do u feel the tension from your clutch cable? Or are u pushing the clutch in more for it to engage. Kind of like when ur brakes go out. I'm thinking your synchros/shift forks are screwed. Have you checked ur trans fluid lately?
Old 06-24-2015, 02:14 PM   #11
209stang's Avatar
No I haven't.
Old 06-24-2015, 02:30 PM   #12
Foxbody91's Avatar
Check yours fluids just in case. If u have a stock cable, adjuster and cable you should be able to push up on the clutch it'll self adjust. But I'm sticking with your synchros. Maybe even worn clutch disc but u won't know for sure until u get under there. Do the easy things first, adjust ur cable and check fluids. But it looks like your gonna need a replacement clutch
Old 06-24-2015, 02:36 PM   #13
209stang's Avatar
Which should I go with and prices?
Old 06-24-2015, 03:29 PM   #14
Shifty 5.0's Avatar
My friend had the same problem and it was just his clutch cable
Shifty 5.0 is offline   Reply With Quote
Old 06-24-2015, 03:39 PM   #15
209stang's Avatar
Even if it's tough to go into gear?
Old 06-24-2015, 03:51 PM   #16
Shifty 5.0's Avatar
It got really tough to put into 1st and 2nd and he had to force it in but he found this loose nut on the clutch cable and adjusted it and it all went away
Old 06-24-2015, 04:01 PM   #17
Foxbody91's Avatar
Yea so yank up on ur clutch u should hear a click.
Old 06-24-2015, 04:10 PM   #18
209stang's Avatar
Alright ill do it tomorrow and let yu guys know how it turned out. Thank you for all the help.
Old 06-26-2015, 11:26 AM   #19
So............
Sent from the Bathroom
Old 06-26-2015, 04:20 PM   #20
209stang's Avatar
It's still a little ruff but a little smoother. My bad for not posting yesterday.
Old 06-26-2015, 05:55 PM   #21
Foxbody91's Avatar
Did u pull up on ur clutch? And did it click?
Old 06-26-2015, 08:17 PM   #22
209stang's Avatar
Yeah it was good for a few hours then started to get ruff again. So im unsure what's happening.
Old 06-26-2015, 08:20 PM   #23
Foxbody91's Avatar
Replace your firewall adjuster and check tension on ur clutch cable
Old 06-26-2015, 08:42 PM   #24
209stang's Avatar
I'm not sure how to do that??
Old 07-02-2015, 09:22 PM   #25
209stang's Avatar
So my car was driving good until my car started to get really ruff again is it time for a new clutch or can it be transmission problems??
Old 07-03-2015, 12:17 PM   #26
Foxbody91's Avatar
Riding rough? Gears sticking or grinding? The clutch can mess up the tranny if abused or ignored. Synchros, pilot or T/O bearings. Clutch fork etc can all start tranny issues. Even ur clutch cable if tension isn't where it should be. Work ur way from under ur dash to ur tranny. Start with the clutch cable, quad and firewall adjuster. If problem persist drop ur tranny and look at ur bearings , clutch plate pressure plate and flywheel. Idk what you mean by its still riding rough. More info will help. Specific noises, grinds, sticking gears, soft clutch...need symptoms
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 06:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 07:22 PM
01:29 AM
