Need help with serpentine belt size on powerdyne supercharged mustang - Mustang Evolution
Old 06-24-2015, 08:11 PM   #1
Hey guys I bought a KO60875 stock 5.0 belt but it doesn't seem to slip on no matter how hard I pull the tensioner..I'm not sure if it's the right belt or maybe I'm doing something wrong, my car has no deletions except for the alternator being moved down to the bottom and I believe the smog pump right on top, anyone know what size of or serpentine belt number I need?? Need help asap..thanks!
Sent from my SAMSUNG-SM-N915A using Mustang Evolution mobile app
baynotch650 is offline   Reply With Quote
Old 06-25-2015, 01:05 PM   #2
wbrockstar's Avatar
If its a 8-9psi kit with stock crank pulley,my buddies 92 uses the
Goodyear gator belt part #4060500
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 06-25-2015, 01:27 PM   #3
I still wrap that pulley around the crankshaft pulley right? Because in front of it there's another pulley but that goes with the belt that goes to the supercharger
Old 06-26-2015, 11:32 AM   #4
smurf stang's Avatar
Use a piece of string and wrap it around then measure it. Boom done.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 06-26-2015, 07:48 PM   #5
Actually measure the string when the tensioner is almost bottomed out.
Powerdynes are notorious for belt slip and all parts are OOP unfortunately.
Old 06-29-2015, 03:35 PM   #6
wbrockstar's Avatar
Sorry I read your post again and realized I gave you the part # for the crank pulley to supercharger pulley belt.You're looking for the drive belt part # that goes around everything but the supercharger pulley.It should be a OEM length belt unless you've changed accessory,crank,smog pump pullies to a size different from stock(I.E.under drive pulleys,etc)
Your crank pulley probably has another pulley installed into it so that the inside belt runs around the crank/wp/smog pump/alternator/ac & tensioner pullies then the outside belt runs around the supercharger/tensioner & extended crank pullies.I would use the string trick to measure since the stock length belt you've tried doesn't fit.One of your pullies must be larger/smaller than OEM size,otherwise your belt should fit.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
New serpentine belt!! HELP FORDuhl6 1996-2004 Mustang GT 9 05-01-2012 12:43 PM
03:05 AM
