Coolant Leaking Badly - Mustang Evolution
Old 06-25-2015, 11:05 PM   #1
Coolant doesn't leak when it's just running. I drive around for awhile, then, when I come to a complete stop, it comes pouring out through this spout. Is it my thermostat?
Perez152 is offline   Reply With Quote
Old 06-25-2015, 11:07 PM   #2
Shifty 5.0's Avatar
No that is your coolant overflow tank. If it's coming out of there id get new one instead of trying to patch it because it looks pretty rough
Shifty 5.0 is offline   Reply With Quote
Old 06-25-2015, 11:11 PM   #3
Alright thanks. Just bought the fox body today. She's a fixer upper.
Old 06-26-2015, 11:10 PM   #4
infamous281's Avatar
Just keep a eye on that temp. It's nothing major but it could be if you become careless.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 06-26-2015, 11:14 PM   #5
Shifty 5.0's Avatar
It is major if it's pouring out when he comes to a complete stop. He will run low on coolant quick! You can find used overflow tanks cheap
Old 06-27-2015, 08:32 AM   #6
wbrockstar's Avatar
The radiator cap opens to allow coolant flow between the radiator and reservoir bottle.If the cap isnt working properly,it could be letting coolant go into the bottle,but not closing.If it doesnt close, coolant will continue to fill the bottle until it reaches its max capacity & once this happens coolant will begin coming out of the spout you're referring to.The cap should open/close at the appropriate time,to allow coolant to flow from the radiator to the reservoir bottle and the reservoir bottle back into the radiator.When I say "the cap opens and closes" it really just means the valve inside the cap moves in a way that allows coolant to flow in one direction or the other.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Leaking coolant when parked rollo1987 1996-2004 Mustang GT 5 08-25-2014 06:27 PM
Leaking coolant denises08 2005-2010 V6 Mustang 3 07-26-2013 06:24 PM
Leaking Coolant 88gtCc 1979-1995 Mustang GT 14 05-14-2012 03:47 PM
lower intake manifold leaking coolant shustwit Pre-2005 V6 Mustang 4 06-17-2011 11:28 AM
Coolant leaking 08v6 1979-1995 Mustang GT 2 06-05-2011 03:42 PM
11:31 AM
