New clutch squeaking noise - Mustang Evolution
Old 07-01-2015, 03:42 PM   #1
Hi everyone, I know a bit about squeaking noises from the clutch, so my question is if I leave it, will the noise every go away? Do I need to get it redone, pulled out again and put backed in? Thanks for your help....
pony5.0 is offline   Reply With Quote
Old 07-04-2015, 09:52 AM   #2
Describe the squeal and when it occurs. It might just be that the preload on your throw out bearing is not set right.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-05-2015, 07:56 PM   #3
Hi there, happy 4th, the squeak sound is like a wheel turning and every time it hits a certain point it squeaks. So, when you drive fast the squeak sound is almost a solid sound and when you sit at a red light the sound goes back to a slow squeak. When I touch the clutch peddle and push it in just an inch the sound is gone, and when I push the clutch all the way in the sound disappears. I hope the explanation helps..... Thanks for the help..
Old 07-05-2015, 08:27 PM   #4
Throwout bearing is not properly preloaded. You pushing the clutch in a little and the sound going away is preloading the cable/bearing and making it quiet.
If you have a stock clutch quadrant, grab your pedal and pull UP on it and you should hear a zipping noise which is the self adjusting mechanism. If you have an aftermarket setup, which is optimal you need to tighten your firewall adjuster enough to preload the throwout bearing.
If the stock mechanism trick does not work, I would get a Max Motorsports quadrant and a Fiore microclick firewall adjuster and manually preload the bearing.
Old 07-05-2015, 08:40 PM   #5
Ubnbit's Avatar
^ why Scotty is the man!
Old 07-05-2015, 09:01 PM   #6
Thanks Scott, I will try that tomorrow and let u know. Thanks for taking the time to help. Much appreciated.....
Old 05-02-2016, 03:54 PM   #7
hi there, I just bought a boot cover for my 94 GT convertible, no instructions came with it. (eBay) it a factory part. my question is does the cover sit outside of the frame where the roof sits? or do you tuck the cover under the frame so you can see that black plastic lip that goes around the the roof line.. thanks..
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
Squeaking noise coming from belts sLbxO143 1996-2004 Mustang GT 11 02-25-2013 02:08 PM
weird squeaking noise 86 muscle 1996-2004 Mustang GT 8 10-08-2011 03:23 PM
Squeaking noise Nog51 Pre-2005 V6 Mustang 13 12-21-2010 09:18 AM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
02:18 PM
