Opinions? - Mustang Evolution
Old 07-02-2015, 09:33 AM   #1
Foxbody91's Avatar
Opinions?
Adult driven 1988 Mustang GT: Just dialed (tuned) in by Master Ford Tech, 5.0 approx 15K on motor, Mass Air Conversion, E-303 Cam, GT-40P Heads, 1.72 Cobra Roller Rockers, Edlebrock Performer Upper Intake, 75mm Throttle Body, 24lb Injectors, MSD Distributor, Under Dive Pulleys, 3:73 Rear, 255 LPH in tank electric fuel pump, Kirban Adjustable Fuel Pressure Regulator, BBK 2" shorty headers, H pipe with 2" stainless steel exhaust, Borta Mufflers, High Torque mini starter, High Intensity Xenon head lamps with LED Halo, T-5 Tremec Transmission, Short Throw Shifter, Adjustable clutch, Converted to 5 Lug wheels 17x9, Converted to adjustable Ford Racing front and rear disc brakes, all new upper and lower rear control arms with 2.5 lowering springs, Poly bushings through out, new shocks, new coil over struts, Adjustable Camber, Bama Performance 4 bank chip, 4 point harness' with racing seats, Harness Bar. I have all of the OEM parts, including the seats. Plus extra parts that haven't been installed. Very reliable car, I am the 3rd owner.
This is an 88 gt I've been watching. Of course i will check the car out for leaks, rust, funny noises or grinds but as far as the setup. I know the exhaust may b a bit smaller than OEM but anything else I should look out for?
Foxbody91 is offline   Reply With Quote
Old 07-02-2015, 09:53 AM   #2
Sounds like an impressive piece. I'd want a build list/receipts of the mods.
If everything seems under control, you're not going fast enough.
Old 07-02-2015, 10:34 AM   #3
Foxbody91's Avatar
Lol heard that. Guy told me it needs odometer. Back tires need balancing. Door handles need replacing soon.
Old 07-02-2015, 10:37 AM   #4
That's not too bad for a 27 year old car.
Old 07-04-2015, 09:51 AM   #5
That's all common stuff and easy to fix.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-04-2015, 10:02 AM   #6
Foxbody91's Avatar
Also I noticed two screws poking out behind my back tires ill post a pic when I get off work. Vacuum leak somewhere definitely. And sometimes when I'm in low gears and I brake I'll hear a clunk under my driver side. I'll have to lift it and look at it other than that the car has been driving great no real issues yet. Will have to get used to the EFI setup, my first fox like this my last two were carbed
Old 07-04-2015, 07:05 PM   #7
Foxbody91's Avatar
Name:	ImageUploadedByMustang Evolution1436058300.748771.jpg
Name:	ImageUploadedByMustang Evolution1436058328.229121.jpg
Old 07-05-2015, 09:43 AM   #8
Shifty 5.0's Avatar
Those 2 screws are where your quad shocks used to be. The guy must of took them off
Shifty 5.0 is offline   Reply With Quote
Old 07-05-2015, 05:37 PM   #9
smurf stang's Avatar
Clunk might be the lower control arms, driveshaft/u joint, bushings
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 07-12-2015, 09:29 PM   #10
89 5.0 stang's Avatar
ya those shocks where put there from factory to reduce wheel hop...which they failed to do..i was told by some guy to remove those.
Sent from my LG-D415 using Mustang Evolution mobile app
89 5.0 stang is offline   Reply With Quote
Old 07-12-2015, 10:13 PM   #11
Foxbody91's Avatar
I hear it when i push clutch in and brake it seems like
Need Opinions - My new Logo mattstang The Bar 22 11-26-2003 02:12 PM
Opinions? BlueDonkey Regional Mustang Discussion 5 10-11-2003 11:24 PM
NEED OPINIONS ON THIS CHIN SPOILER! mattstang Mustang Audio & Video 22 10-02-2003 10:33 AM
Need some opinions on this grille for my car. greenflash00 Mustang Audio & Video 9 09-21-2003 10:01 PM
need opinions .:DarkEntity:. The Bar 5 08-03-2003 07:54 AM
11:18 PM
