1989 5.0 LX - Mustang Evolution
Old 07-07-2015, 03:28 AM   #1
89FoxBody50LX's Avatar
1989 5.0 LX
I picked this 1989 5.0 LX in late April and I figured I'd make a thread to show y'all what I got.
Missing paint in few few areas.
Mod list: 302 CI.
Forged bottom end internals
B303 cam
Gt40 Heads
Gt40 upper & lower intake
Bbk throttle body (70mm)
Bbk egr delete
Adj fuel pressure regulator
Bbk chrome headers
Bbk x pipe
Flowmaster 40's (dumps before rear end)
Phoenix friction stage 2 kevlar clutch
Aluminum driveshaft
Svt wheels/nitto nt555r tires
5 lug conversion
Rear end out of a 05 mustang GT (Trickflow cover)
3.73 gears
Cross drilled/slotted front rotors
Steeda lowering springs
Upr adjustable upper & lower control arms
Upr camber caster plates
Steeda sub frame connectors
4 point roll cage
Battery relocated in trunk with killswitch
Line lock
Brake adjuster (change pressure from front to back)
Pro force performance built T-5 Transmission. Rebuilt @ 51930
Car has just rolled over to 52K original miles.
Name:	ImageUploadedByMustang Evolution1436261058.359240.jpg
ID:	186643Click image for larger version
Name:	ImageUploadedByMustang Evolution1436261089.977140.jpg
ID:	186644Click image for larger version
Name:	ImageUploadedByMustang Evolution1436261137.430997.jpg
89FoxBody50LX is offline   Reply With Quote
Old 07-08-2015, 06:49 PM   #2
smurf stang's Avatar
Clean car but was the motor rebuilt cause you have listed a forged bottom end?
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 07-08-2015, 07:12 PM   #3
dwbrand's Avatar
Love the color, looks like a nice car!
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-09-2015, 05:48 AM   #4
All 87-early 92 cars had forged pistons. Even the 92.5-01 5.0 pushrods with the hyper pistons are plenty strong. The block is the weak link on the 5.0 pushrod which is why I never understand why ppl spend big money on building it up.
Old 07-09-2015, 03:43 PM   #5
wbrockstar's Avatar
Looks like a nice ride,especially with only 52k miles.The b cam is the only thing I would change if you decide to up the performance at all,otherwise leave the b cam in it.You could also throw some 1.7 RR on it if you decide to keep the b cam.That would raise lift from its current .480" to .510" The b cam is a 4-6000 rpm type can so there are better cams out there for more lower-midrange power,which is better for the street.What kind of idle quality do you get??
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 07-09-2015, 03:53 PM   #6
Hell no leave the B cam in. Pairs amazingly well with those heads/intake.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-09-2015, 07:45 PM   #7
Oh I know but curious to what the OP meant.
Old 07-09-2015, 10:03 PM   #8
Idles real low, 750'ish. Not much of a lope, still looking for a better cam to throw in. Any suggestions? (Not too outrageous of cams)
---------- Post added at 04:03 AM ---------- Previous post was at 04:02 AM ----------
Motor was indeed rebuilt.
Old 07-10-2015, 05:22 AM   #9
wbrockstar's Avatar
I guess some guys put different pistons in to bring compression up and/or sometimes for less weight too,if its a light weight piston,even though the stock pistons are already forged.The rods & crank aren't forged though,so if the previous owner really did change the rods & crank to forged components, this engine is ready to go up to 400-500hp,as long as the block holds up as stated by Scotty.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 07-10-2015, 05:52 AM   #10
The stock internals from the factory are good for more power than the block can take.
Nothing wrong with the b cam either, those heads don't flow enough to make use of much anything else. If you want, put in some 1.7 rockers. Good tune on that car should do 275 to the wheels and easy 12s with suspension and a decent driver. Throw a 150 shot on it for track days and roll.
Old 07-17-2015, 03:27 PM   #11
prototype ss's Avatar
Where should normal rpm idle be at?
prototype ss is offline   Reply With Quote
Old 07-17-2015, 03:28 PM   #12
Where should normal rpm idle be at??
Old 07-17-2015, 03:29 PM   #13
My bad dont know how that posted twice..
Old 07-18-2015, 12:12 PM   #14
750 is fine. Now maybe you need 800 or 850 cause of the cam.
Old 07-18-2015, 09:30 PM   #15
I have an E cam and it idles at about 1k or 1100rpms?
Old 07-19-2015, 05:30 PM   #16
E cam should not idle any higher than other cams. If it is, you are untuned or your tuner sucks.
Old 07-19-2015, 07:49 PM   #17
wbrockstar's Avatar
You can always do a base idle reset to help get the idle situated to your liking.
http://sbftech.com/index.php/topic,1031.0.html
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Old 07-19-2015, 07:57 PM   #18
I bought he car about 2 years ago and has always been at that idle.. How would I bring it down to the 800 range? My car is carbed I don't know if that matters.?
Old 07-19-2015, 08:51 PM   #19
dwbrand's Avatar
1989 5.0 LX
Should be an idle adjust screw on the carb.
Does it always idle that high or does it ever come down? Might be an issue with a choke if you've got one.
1968 Mercury Cougar
Old 07-20-2015, 07:04 AM   #20
E cam has a 110 lsa that can be hard to get to idle right on a carbed car.
Old 07-20-2015, 02:35 PM   #21
Its a Holley carb Ill see if it has that screw to help the idle.. But yea it always stays right there. Never gets any higher or get any lower... And ScottyDoesntKnow what is lsa?
1989 Mustang LX 5.0 convertible :: 1989 Ford Mustang DEJAVU3 Member Garages 0 03-23-2015 07:09 PM
What is the difference between a 1989 Mustang LX 5.0 and 1989 Mustang GT? kele74 General Mustang Discussion 8 03-21-2010 10:03 PM
What parts would i need to convert a convertible 1989 5.0 LX mustang to a 1989 Mustang GT? diwali General Mustang Discussion 1 03-17-2010 09:40 PM
What is the difference between a regular 1989 mustang gt and a 1989 mustang gt foxbody? collin General Mustang Discussion 9 03-17-2010 09:42 AM
1989 Vert 5.0 Conversion Bulldog Stang Mustangs for Sale and Wanted 2 09-12-2005 02:23 PM
02:32 PM
